wtf????
Old Mar 10, 2011 | 10:01 AM
bcaughhorn's Avatar
bcaughhorn
wtf????
I drove my truck about 60 miles with the cruise set about 65. As I'm getting off the interstate I shut the cruise off, make the loop onto 49. I push the throttle. Nothing???? I hold it for a few seconds the truck starts to rev up and take off. I can't drive through gulfport like this. So I take the first right and try to go. Same thing.... Nothing. Hold it for a few seconds and it picks up and takes off. Help!!!!!!
Old Mar 10, 2011 | 10:13 AM
Robert6401's Avatar
Robert6401
Is the truck revving, but not moving? Or is there just no response to the throttle input at all?
Old Mar 10, 2011 | 10:16 AM
Kajtek1's Avatar
Kajtek1
Sounds like bad pedal position sensor. I had mine acting for a year.
PaysonPSD's Avatar
PaysonPSD
Sounds like a TPS (Throttle Position Sensor) or IVS (Idle Validation Switch). Both located on the throttle pedal. Dependig on year they are seperate parts or built as one. You can try cleaning the IVS contacts. The IVS is normally open and when pressure is applied to throttle the contacts should make to close the switch. If the PCM does not see the closure it ignores the TPS signals.
Here's some info for seperate TPS-IVS. LINK
Old Mar 10, 2011 | 10:25 AM
bcaughhorn's Avatar
bcaughhorn
No response to the throttle pedal. After I hold it down for a few seconds it would rev up and take off like I was racing
Old Mar 10, 2011 | 10:34 AM
bcaughhorn's Avatar
bcaughhorn
I unhooked my edge ezf and its going fine for now......
I drove about 10 to 15 minutes to the hospital. Its sitting the parking lot for now. I gotta visit my grandma for awhile. She don't have much time left the truck will be there
Old Mar 10, 2011 | 10:50 AM
zx250's Avatar
zx250
Of the next Riffraff East
By all means spend time with your Grandma. We'll be here when you're ready to proceed. Just for fun, check your oil level, but the TPS sounds most likely, but removing the edge should not have affected it.
Old Mar 10, 2011 | 10:54 AM
bcaughhorn's Avatar
bcaughhorn
I checked the oil 2 days ago. It was full. I haven't had any leaks. This is the first time I drove it since I checked the oil. I unhooked the edge for ****s and giggles thinking it wasn't gonna help. I was thinking of the pedal. Sitting in the parking lot of home depot I had nothing else to do
Old Mar 10, 2011 | 11:01 AM
zx250's Avatar
zx250
Is the Check Engine Light coming on when it does that? Do you have a way to check for codes?
Old Mar 10, 2011 | 11:03 AM
bcaughhorn's Avatar
bcaughhorn
No light. No way to check codes either. I can probably call a friend and have it checked. But I gotta get it to him. That could be a problem
Old Mar 10, 2011 | 11:08 AM
zx250's Avatar
zx250
Couple of things I would check.
The little tin nut on the IPR, if they come off, all sorts of issues can occur.
Oil level, again.
Reason I say this, when my IPR went south, the only way I could get it to move at all was to hold the pedal to the floor until I got moving a little, then it would get a little better, but I was getting a intermittent light
Old Mar 10, 2011 | 11:11 AM
bcaughhorn's Avatar
bcaughhorn
That's what mine was doing without the light.
Old Mar 10, 2011 | 11:15 AM
zx250's Avatar
zx250
If the nut has come off, the that's an easy fix. If you are getting the 1211 code, then you may have a bad IPR or ICP. Some have luck cleaning the IPR, but for me, the only cure was a new one. My light didn't start coming on until it got to the point it just about wasn't going.
Old Mar 10, 2011 | 11:20 AM
99hunter's Avatar
99hunter
I wouldn't be surprised ifit is your edge. Mine starteddoing weird things after a year or two needles to say it ended up in the garbage. Other friends of mine ended up with diferant peoblms and also got rid of them.
bcaughhorn's Avatar
bcaughhorn
Where is the ipr? I will check later. It looked like my plug for my icp had oil in it but I didn't look real good. I was in the home depot parking lot and kinda pissed.
