Modular V10 (6.8l)
Sticky Throttle
Old Feb 12, 2013 | 11:57 PM
Hogtrapper's Avatar
Hogtrapper
Sticky Throttle
I have a 2000 F350 4X4 with a 6.8 (V10) and a manual 5 speed. My problem is the throttle sticks very often but not all the time. It doesn't seem to matter what speed I drive it, either around town or on the highway the throttle doesnt want to return to idle when I release the accelerator and push the clutch in. When it does this I can firmly pat the accelerator pedal, usually once, and it will return to idle. If once doesn't do the trick twice will. Part of the linkage was rubbing a plastic cover on top of the engine and I thought that was the problem but I remover the cover and it continues to do the same thing. It kind of reminds me of the old days when the butterflies would stick on a carburetor. Any suggestions on what to do/check would be greatly appreciated. Thank you in advance for your input, thoughts, and suggestions.
Old Feb 13, 2013 | 12:20 AM
jh818's Avatar
jh818
Have you cleaned the throttle body with carb cleaner?
Old Feb 13, 2013 | 08:26 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
jh818 might be on the right track - corrosion or crud will keep the butterflies open.
Easy test - remove the cover on the throttle body and push the throttle open with your hand. Back off real slow and see if it returns to the throttle stop screw. If it doesn't start removing the cruise control servo cable, then the throttle cable. If it still won't return all the way back to the stop screw, pull it and clean it.
Old Feb 13, 2013 | 12:47 PM
Hogtrapper's Avatar
Hogtrapper
Thank you gentlemen for your input and ideas, I will do this asap and report back.
Old Feb 15, 2013 | 11:19 AM
Jmoen7's Avatar
Jmoen7
Definitely on the right track, had the same issue with my throttle holding around 1800 rpm, a cleaned throttle body will do the trick, not so often that the cables gum up but i'm sure that can happen aswell
Old Feb 16, 2013 | 07:54 PM
Hogtrapper's Avatar
Hogtrapper
Thank you gentlemen for the help, it took some doing but I got it cleaned and so far so good.
Old Feb 20, 2013 | 10:58 AM
krewat's Avatar
krewat
Thanks for reporting back Rep points sent.
Old Feb 21, 2013 | 06:34 AM
JWA's Avatar
JWA
I rep'd both of you guys!
This is a good follow up---a somewhat routine item for maintenance or at least checking on occasion.
EzPc
Aug 4, 2018 10:34 AM
WarWagon85
Jun 28, 2017 09:09 AM
modeltford
1997 - 2003 F150
Jul 9, 2014 11:16 PM
77300i6
1997 - 2003 F150
Jul 4, 2011 09:21 PM
sail2244
1983 - 2012 Ranger & B-Series
Mar 6, 2010 07:03 PM
