1950 Ford F2 misc parts
Category: Accessories
Price: $0
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): CRX & pre '92 Civic
Item Condition: MI
Engine: Part suitable for gas truck
- Original gas tank in good condition
- 2 wheels & tires P235R80-16 8 lug 16"x6" tubeless
- Original Holley 94 Carb - Reconditioned by Vintage Speed (like new - less than 100 miles)
- Ford moon hubcaps (4 - like new)
- Headlights 2 Sylvania Blue & 1 regular
- Door seals lower - new, never installed
- Stock flathead V8 intake manifold
- Front brake set for F2-F3 (12" drums, keepers, shoes, backing plates, wheel cylinders, etc.)
- Complete all exhaust system (pipes, muffler, tailpipe, chrome tip) like new. Used less than 100 miles before removal & stored in barn. Cost over $500 installed when new.
- Stock flathead V8 air cleaner painted Ford Engine Gray - Excellent condition.
- Carter BBD carb with adapter to fit stock three-bolt manifold.
Make offer
See pictures at:
1950 Ford Flathead V8 pickup truck parts
I do and the rear shoes & drums are brand new. . . but I won't be selling anything on the rear axle until I find and install a Ford 9" rear axle.
Pete, if you haven't sold the F2 wheels yet, please PM me with a price on one. I don't have a spare tire for mine at the moment. Thanks.
Doug
Doug
revision
Sold a few parts and found some more:
These parts should fit 1948-1952 Ford pickups.
Some pictures available at 1950 Ford Flathead V8 pickup truck parts
- Need a spare tire? I have 2 P235R60-16 tires mounted on tubeless-type wheels (eight lug 16" x 6") that came off my 1950 F2 pickup - $65 each
- Original Holley 94 Carb - Reconditioned by Vintage Speed (like new - less than 100 miles) - $140
- Ford moon hubcaps (4 - like new - less than 100 miles) - $195
- Headlights 2 Sylvania Blue & 1 regular - $10
- Door seals lower - new, never installed - $35
- Intake manifold - stock flathead V8 - $25
- Front brake set for F2-F3 (12" drums, keepers, shoes, backing plates, wheel cylinders, etc.) - re-conditioned - $95
- Complete exhaust system (pipes, muffler, tailpipe, chrome tip) like new. Used less than 100 miles before removal & stored in barn. Cost over $500 installed when new. - $99
- Stock air cleaner painted Ford Engine Gray - Clean (no oil) & excellent condition - $65
- Carter BBD carb with adapter to fit stock three-bolt manifold - $120
- New aftermarket turn signal kit - $110
- Original brake master cylinder - $10
- Clutch pedal return spring (used but fully functional)
- Master Cylinder pushrod (used but fully functional)
- Clutch pedal adjustment rod (new)
$95 for everything from the backing plate on out to the drums. All parts have at least been been reconditioned. Some are new.
See 1950 Ford Flathead V8 pickup truck parts
Do you by chance still have the moon hub caps? Email at docrocheeriekmc@gmail.com. Dont know if i can pm yet. Send a pic if you got them.
Cougar54
17
06-20-2015 10:05 PM
CarlH
10-29-2009 08:42 PM
dschr
01-13-2005 10:56 AM
