No Power Help!!!!
Old Dec 11, 2014 | 05:22 PM
ProjectDually's Avatar
ProjectDually
Originally Posted by lindstromjd
Or to just fill it up with automatic transmission fluid... Same principle, same effect.
A guy in the office opposite mine was just telling me about using ATF added to the oil. Said something about the detergent properties in the ATF will really clean out the oil deposits in the engine.
Old Dec 11, 2014 | 06:28 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
Yes it will. My concern would be the detergent possibly eating the injector orings though.
Old Dec 11, 2014 | 06:51 PM
madpogue's Avatar
madpogue
Does this "guy" run an engine that depends on its lubrication oil to power the injectors under extremely high pressure? Additives in engine oils are controversial enough, for engines that simply use the lube oil as lube oil (like gassers and mechanically-injected diesels). But HEUI engines like ours are not the place to be experimenting with oil additives.
Old Dec 11, 2014 | 06:53 PM
ProjectDually
I asked him again, he wasn't sure. I did some googleing and found guys using ATF as a FUEL additive too. Good for sticking lifters, INJ cleaning, and removing deposits and gunk. Said to only run for a short period, or a few hundred miles, and then change the oil and filter. Its mineral oil based, so I'm not sure any harm would come in using it short term. Maybe a diesel mech could give some light. Somebody who has been running with the 7.3 for a long time too, and has done it. Seems like a lot of forums talking about it. Maybe Bill could shed some light on it.
smokin7.3
Apr 3, 2012 11:37 AM
biggensprowerstroke
Mar 7, 2009 03:25 PM
stewartsrus
46
Oct 24, 2008 09:56 AM
Novak974
1997 - 2003 F150
18
Aug 16, 2005 05:20 PM
mach10533
General Automotive Discussion
Feb 22, 2004 12:01 PM
