Sponsored by: Auxito
Losing Power
Old Aug 1, 2005 | 06:43 PM
Novak974's Avatar
Novak974
Losing Power
I have a 1999 F-150 and recently I have been losing power going up hills. I have changed the fuel filter. What other options should I look at. Thanks
Old Aug 1, 2005 | 06:56 PM
triton_2002's Avatar
triton_2002
Welcome to FTE!
What kind of maintenance has the truck had? How many miles? Does it happen only on hills? Is the check engine light on? Need more info to help you out.
Old Aug 1, 2005 | 08:58 PM
LxMan1's Avatar
LxMan1
Tune-up? Clogging cats? Need more info. Engine? trans?
Old Aug 2, 2005 | 01:05 PM
Novak974's Avatar
Novak974
The oil has been changed every 3000, and the air filter was changed 2000 ago. It just happens up hills, has 75,000 miles on it, and Check engine light has come on just once.
4.6L
Automatic trans
Old Aug 2, 2005 | 06:38 PM
bac327's Avatar
bac327
Same Problem
I am having the same problem on my truck too. Its an 00 F150 with about 100k miles on it with regular maintenance. K&N Filter. Its just been tuned up with plugs and fuel filter. Cats have been checked. Still same problem. I have also noticed a 3-4 mpg drop in fuel economy. No check engine light though. Any suggestions?
Old Aug 3, 2005 | 06:31 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome bac327, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 3, 2005 | 08:18 AM
lancekilgore's Avatar
lancekilgore
Tranny fluid change and filter? When was the last time? Just a thought.
Lance
Old Aug 3, 2005 | 10:15 AM
bac327's Avatar
bac327
I'm not sure. Not since I've had the truck. The fluid looks good, but that's all I can say. Is that a possibility?
Old Aug 3, 2005 | 10:44 AM
BillyBob69's Avatar
BillyBob69
Fuel filter? Not always caught on a tune up. Could be pulling more ca-ca into the fuel path when you push it harder for the uphills.
Old Aug 3, 2005 | 11:03 AM
lancekilgore
It is a slim possibility, tranny has to work harder shifting ect. something to try especially since you have not done it. The filter can get clogged and the tranny strains to pull the fluid through. But normally you will have hard shifting if this is the case as well.
Lance
Old Aug 3, 2005 | 12:08 PM
bac327's Avatar
bac327
When it does shift down at high speeds while cruising it is a very hard shift. That may very well be the problem. Thanks for the suggestion.
Old Aug 3, 2005 | 01:46 PM
Novak974's Avatar
Novak974
It feels like it is flooding out when I go up hills. Could the spark plugs be bad? It almost feels like it surges when it goes up hills. Any help??
Old Aug 3, 2005 | 06:12 PM
lancekilgore
what was the code wehn the check engine light came on? Have the codes checked agien there may be another code that was not bad enogh to activate the light. (pending codes) could help to figure out.
Lance
Old Aug 3, 2005 | 08:15 PM
Novak974's Avatar
Novak974
I have not checked the codes, will have them checked and post again. Thanks
Old Aug 4, 2005 | 03:56 PM
cjl's Avatar
cjl
are you using the a/c when this happens? My truck did this too only when the a/c was on. it ended up being a computer problem. the computer forget to adjust the engine when the a/c was on. i had it reflashed and it went away.
