Cluster...Again
Old Dec 7, 2014 | 03:38 PM
Shadowrider123's Avatar
Shadowrider123
Cluster...Again
I finished the cluster in my 64 and put it all back together on Monday.
I get in the truck this morning and the speedo glass is cracked. I put a piece of small diameter tubing between the glass and bezel to keep it from rattling and Im guessing I put to much pressure on the glass.
Now Im in search of a new speedo glass.
Old Dec 7, 2014 | 05:56 PM
ihcc104's Avatar
ihcc104
Any glass shop that has CNC capabilities and a center scribe and compass can cut you a new piece out of 1/8" glass. Cheap too
Old Dec 7, 2014 | 08:14 PM
Shadowrider123
I was thinking 3/16 so it would fit tighter in the bezel.
Old Dec 8, 2014 | 10:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C1TF-10880-A .. Round Speedometer Instrument Cluster Lens - 6 1/8" diameter / Obsolete
Applications: 1961/66 F100/1100 / 1966/77 Bronco.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
MCDONALD OBSOLETE PARTS CO. in Rockport IN has 1 = 812-359-4965.
MINUTEMAN FORD TRUCKS in Walpole MA has 1 = 508-668-3112.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 670-722-5371.
OBSOLETE RELIABLE PARTS in Nashville GA has 2 = 229-686-5101.
Old Dec 9, 2014 | 07:43 PM
resonateur's Avatar
resonateur
When I put stuff like that together I use a thin tip plastic disposable monoject syringe. Fill it with silicone/rtv or whatever the situation calls for and cut the tip to the diameter I want. You can run a tiny bead of silicone on the speedo face, let it dry a little then set your glass. You just made a 1/32" silicone gasket. Those things have a hundred uses in the shop. They're Monoject #412. Search 'em online or pm me and I'll send you a couple to try!
Speedjester
Dec 15, 2014 07:17 AM
EvinrudeDude300
1947 and Older Ford Trucks
Dec 4, 2011 03:08 PM
Voh
Mar 7, 2008 02:36 AM
qman
Oct 18, 2006 01:46 PM
