Fuel Economy Decrease
I only noticed a 10% decrease with the oxygenated fuel on my older vehicles. My 2007 Toyota wasn't affected nearly as much. Your '06 should have a wide band O2 sensor, which is better able to deal with oxygenated fuel and your mileage hit seems too high to me at over 20%.
If you've been experiencing unusually cold weather and warm up your Explorer for 10 minutes before driving, that might explain some of it. Also, it will run rich longer until warm and that will affect mileage.
If it were just due to the winter season, you should have noticed this last year at about the same time. But, if you don't keep records, maybe not. I think your mileage decrease deserves a little investigation.
How many miles does your '06 have? A few places to check...You can check and clean/replace air filter, 02 sensors could be slowly dying out, mass air sensor could be needing a cleaning...numerous things to check.
My gas mileage does decrease in the winter a little. (as earlier mentioned) Mostly, because I will let it warm up a little longer than normal, run the heater all the time (which is just like turning on AC because Ford wants to keep the AC compressor lubed year round) and I don't check my tire pressure as much as you do.
Going from 22 down to 17 mpg is quite a jump..keep looking
Not sure if that will help but I gave it a shot. Good luck..
I have a 2004 Aviator AWD and I noticed the same thing, but my mpg dropped down to 17 from 19. I think the main thing I found to bring the mileage back up was to find a place that sells ethanol free fuel. It does cost more, but it runs better, starts cold better and saves your injectors too. I used to work at Ford when the fuel was better and we used to get a lot of low mpg complaints from mostly truck owners :-)
This was in Colorado Springs, CO and we'd still hang the 1 gallon container on the vehicle and test the mileage and surprisingly the 5.8L F-150 pickups would get at least 17 mpg on the highway at speeds of 55 - 60 mph. It was usually because they were using cheap gas and have a heavy foot on the gas pedal.
One other thing I found with my Aviator causing a problem was a dragging brake caliper on the left rear--that made a 1.5 mpg difference. I also run all Amsoil lubricants which is hands down the best way to sustain the life of your vehicle and get the best mileage. I was in the Air Force for 25 years and found out the base stock components in Amsoil are the same ones for the jet engine oil (7808) we use in the F-15 fighter aircraft. I got into the jet engine technical manuals and verified this.
If you don't have any leaks or mechanical problems and plan on keeping your SUV I would use Amsoil products in it. Plus the engine oil is warrantied and you can run it 12,000 miles between oil changes as long as you are using the Amsoil filter. If you spend another $175.00 or so for the external oil filter kit you can run the engine oil 25,000 between changes, but I stick to the standard spin on filter and go 10,000 -11,000 miles between changes. This saves money too. I would not try and run Mobil 1, Castrol or Royal Purple 10,000 miles. Their additives and detergents burn off--that's what the result was on testing all the oils against each other.
Let us know if you found anything wrong causing your mileage to drop off, but do the easy things first like switching fuel and checking for things like I mentioned.
