'05 powersteering issues
Old Dec 6, 2014 | 12:08 PM
FordFamily6's Avatar
FordFamily6
I have some chirping under the hood and think i have found multiple issues, and would really appreciate your input. I replaced the two stationary idlers as they were not rolling smooth and the loud chirping went away. I still have a squeek and then metallic screaching noise when turning when cold. Noise goes away when warm. I loosened the belt again and grabbed front of power steering pulley and can move it in and out a noticable amount, probably a hair less than 1/8". The belt tensioner pulleys check out good. Any experience with power steering pump problems and changing them out, special tools, etc. i'll have to rent the clam shell puller for the pulley.
Old Dec 6, 2014 | 06:50 PM
firedaniel's Avatar
firedaniel
mine wasnt too bad. i have a 06 but its 2wd. Make sure to have a 18mm wrench. its alittle tight but doable
cixelsyd
1997 - 2003 F150
Jun 2, 2013 10:18 PM
underp2
Aug 12, 2012 09:00 AM
WALJON
Dec 30, 2007 02:40 PM
Ford Fx4
2004 - 2008 F150
13
Dec 5, 2006 05:04 PM
scottpower
25
Feb 24, 2005 08:07 AM
