Sponsored by: Auxito
Serpentine Noise
Old Jun 1, 2013 | 10:22 PM
cixelsyd's Avatar
cixelsyd
Serpentine Noise
Noise coming from somewhere in the serpentine setup.
Replaced the idler pulley, it was a little rough. Tensioner feels fine.
Wash about to pull the fan clutch off when the noise stopped for a week.
It's back. Now I'm leaning towards the power steering pulley / pump, although I have no troubles with the steering otherwise.
Any tips on how to isolate the problem source?
Old Jun 2, 2013 | 07:35 PM
blueeyedfordguy's Avatar
blueeyedfordguy
Describe the noise, screetching and squeeling? Put the belt under a load I.e: turn the steering wheel and have the engine in gear and hold your foot on the brake. This puts a load on the belt from the power steering pump. If it squeels then your tentioner may not be putting enough force on the belt. Does the belt wobble or operate in a straight line? Is the belt cracked or missing ribs? Could be time for a new belt if its cracked it is dry rotted like an old tire and doesn't grip the pulleys like it should and it just slides over them causing noise. Hope this helps. Tell us the noise its making , thanks
Old Jun 2, 2013 | 07:38 PM
blueeyedfordguy
Also remove the belt and rotate pulleys seperately . The idler tentioner and alternator as well the water pump. The water pump should have resistance such as rotating one revolution then coming to a stop. If not its loose and sloppy and worn out. May be causing the noise as well
Old Jun 2, 2013 | 07:46 PM
khadma's Avatar
khadma
Carpenter Local 745
New belt? No? Replace the belt, and clean pulley surfaces.
Goodyear Gatorback serpentine belts work good or pop for Motorcraft OEM
Belt.
What year and mileage on the truck?
Old Jun 2, 2013 | 08:51 PM
R Pope's Avatar
R Pope
First, try spraying the belt with liquid soap. Dust on the belt will make a loud cracking sound, or even a screech.
Old Jun 2, 2013 | 10:18 PM
cixelsyd's Avatar
cixelsyd
Gatorback belt in good condition. Idler pulley replaced. Tensioner pulley is fine.
Noise is an occasional high pitched squeak and sometimes evolves into a solid low grind type of noise.
No noticeable change in noise when steering wheel turned, no noticeable drag on steering wheel or engine when noise occurs either.
Water pump was replaced a year ago and fan clutch about 150K ago. AC and PS are original.
Noise sometimes disappears for a few days, then returns and is constant.
GHeTTo JOe
Mar 10, 2013 04:31 PM
rockcrawler_101
Jan 31, 2010 10:28 AM
db916gt
Jan 1, 2009 05:21 PM
Mr. Fixit
Apr 8, 2005 06:48 PM
gembeau
Apr 17, 2001 07:37 PM
