360/390 heads
Old Jul 18, 2003 | 03:32 PM
Goodold71's Avatar
Goodold71
Question 360/390 heads
What is the difference in the 360 and 390 mills? I have access to a couple of blocks..are the 360 and 390 heads the same? I am trying to build the 390 and have misc parts for 352/360 and 390 engines. I was told all I need to do is switch the crank and rods to make the 360 a 390. What about the heads, pistons is the bore different or just the stroke? Can anyone help ?What do I need to do to make my 360 a 390?
Old Jul 18, 2003 | 03:46 PM
BB's Avatar
BB
360/390 heads
Yes, 360 and 390 heads and blocks are the same. Only difference is the stroke, you need the 390 crank and rods.
Barry
Old Jul 20, 2003 | 05:12 AM
71_4x4_390's Avatar
71_4x4_390
360/390 heads
those rods are also the same.....
Old Jul 20, 2003 | 05:14 AM
71_4x4_390's Avatar
71_4x4_390
360/390 heads
the pistons are different and 360 pistons are not compatable with a 390 crank!
Old Jul 20, 2003 | 05:47 AM
71_4x4_390's Avatar
71_4x4_390
360/390 heads
the rods are not the same... Sorry!
Old Jul 20, 2003 | 06:02 AM
Torque1st's Avatar
Torque1st
Posting Legend
360/390 heads
Please use the edit function to correct your posts rather than posting again. You can edit your posts for up to an hour after making them.
Old Jul 22, 2003 | 09:41 PM
Custom 1975's Avatar
Custom 1975
360/390 heads
What is the difference in the Rods? I recently rebuilt my 360 and installed a 390 crank and Pistons. At the advise of my Machinist, I went with the original rods.
Old Jul 23, 2003 | 03:09 AM
71_4x4_390's Avatar
71_4x4_390
360/390 heads
360 rods are too long, and if used with a 390 crank and pistons will create a total throw that will make the piston collide with the head. Could your original rods have been short rods? Was your engine ever rebuilt before? But as long as it works...
Old Jul 23, 2003 | 10:19 AM
dinosaurfan's Avatar
dinosaurfan
360/390 heads
Yeah, the heads are the same between 360s and 390s. If the engines were produced in the same year. There are 390 heads from earlier 390s that are slightly differant than what the 360s got, but they will still work just fine. Now the rods ARE a bit differant. The 352 & 360 rods are 6.54 long, and the 390 rods are 6.488 long. Sometimes this can work in your favour. Many 390s (73-79 ?)came with 'truck' pistons. They were actually leftover 410 mercury pistons with a 1.66 pin height instead of the 1.76 height that earlier 390s got. Many replacement pistons are the same. What this does is leave the piston way too far down in the bore. If you are willing to do some mix and matching, the long rods will get you closer to a zero deck height ( a good thing ), and that is probably what the machinist did. DF 1.89 throw + 6.54 rod + 1.66 piston = 10.09 in a 10.17 tall bore, .062 taller than if you ran the short rods in this combo.
Old Jul 23, 2003 | 11:26 AM
71_4x4_390's Avatar
71_4x4_390
360/390 heads
how do you do this measurement? Where is pin height measured from?
Old Jul 23, 2003 | 08:11 PM
dinosaurfan
360/390 heads
some pin heights I know from memory, others you can measure if you have the piston and the pin. Push the wrist pin out so you can measure from the bottom of the pin to the top of the piston. Then subtract half of the diameter of the pin. (FE pins are .975 diameter). Is there a certain piston you wanted to know the height of ? DF, @ his Dad's house
