exhaust manifold
Old Dec 3, 2014 | 11:04 AM
shakedownshorty's Avatar
shakedownshorty
exhaust manifold
I have a exhaust leak on the left(drivers) side...I have replaced the gasket once and realized there is one broken stud in the head. It was quite for a while after the new gasket and now is getting louder...other than getting the stud out with allot of work...is there a better gasket or can i go metal to metal with no gasket?
thanks
Old Dec 3, 2014 | 12:49 PM
1986F150six's Avatar
1986F150six
Read this link for some ideas recently presented regarding a broken flywheel bolt. Perhaps one of these will work for you and the exhaust manifold bolt.
https://www.ford-trucks.com/forums/1...heel-bolt.html
Old Dec 3, 2014 | 04:26 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
+1 on welding through a nut to it.
It seems the only way to get decent results in place.
Ford never used a gasket.
I like CopperCoat on both surfaces if I'm going that way.
But, I usually just slot the bolt holes on both sides so the manifold can expand and use a laminated gasket with stainless steel bolts.
This is what works for me on my 460.
Old Dec 3, 2014 | 06:44 PM
maytag906's Avatar
maytag906
Make sure where the leak is at. My 84 had an exhaust leak on the drivers side, turned out it was the heat riser that was leaking.
F-250 WARHORSE
35
Oct 16, 2025 08:45 PM
fmco_muddin
Mar 14, 2009 07:58 PM
jadmt
Dec 18, 2008 11:00 PM
jcd136d
Exhaust Systems
Dec 9, 2008 12:47 PM
smitty7
Oct 27, 2003 08:44 PM
