Help!!!!
Old Dec 3, 2014 | 07:10 PM
Barnhill3289's Avatar
Barnhill3289
Help!!!!
I have a 1986 ford f250 6.9idi 2wd, I just bought it, I was told the injection pump was bad, it poured Whits smoke on the way home, put a new injection pump on it the smk isn't quite as bad, but I barley have any power I can put the pedal to the floor and it just doesnt have the power it should, while I was test driving it with the pedal almost to tthe floor it started making popping noise so I turned around and took it back home, any idea what I need to do? Piston rings, injectors??? I have no clue where to start! Please help!
Old Dec 3, 2014 | 10:18 PM
Jerry's red Ford's Avatar
Jerry's red Ford
White smoke
I have the same truck and engine. When mine started producing white smoke I found a blown head gasket on the left side. Replaced it and the problem went away. Just a suggestion, do a compression test.
Jerry Reichert -Edgewood Washington
Old Dec 4, 2014 | 08:35 AM
Barnhill3289
help
Ok, I'll try a compression test!
cowmilker08
24
May 28, 2013 02:37 PM
Spank226
May 5, 2013 05:38 PM
dsmnightrider02
2004 - 2008 F150
Dec 6, 2009 12:15 PM
nullblaze
1978 - 1996 Big Bronco
Jun 15, 2005 10:41 AM
