Injector crush ring?
Old Dec 3, 2014 | 08:47 AM
Rich8483's Avatar
Rich8483
is there an up or down as to which way that crush/cushion ring goes on the injector? before they are squeazed, they looked like the have a ridge one way. which way is up? or does it not matter?
Old Dec 3, 2014 | 09:39 AM
mueckster's Avatar
mueckster
Here's an illustration of O-ring and copper washer placement. I would favor putting it on as illustrated.
Old Dec 3, 2014 | 10:17 AM
Rich8483's Avatar
Rich8483
clear informative picture. thanks. what should i use to hold it in place during install?
nevermind. the ones i bought have just enough tension on the tip of the injector
Old Dec 4, 2014 | 06:56 AM
Tugly's Avatar
Tugly
I don't count on the friction, I've had one slide down while installing. I dip the injector in oil, then put the copper washer on. This is like wetting a suction cup - the copper washer get oils between it and the face of the injector and the ridges help to form a vacuum in there.
Old Dec 4, 2014 | 07:17 AM
mueckster's Avatar
mueckster
Some washers, but not all, have little tabs inside the holes that lock them in place. Those that don't get a small dab of grease to hold them. Or oil, as Rich mentioned.
cabloom300
Nov 10, 2013 06:26 PM
Xenthrax
21
May 16, 2013 02:41 PM
Visseroth
31
Jul 27, 2011 12:54 AM
nghtrgr
Dec 15, 2008 09:45 AM
paintslinga2010
Nov 16, 2008 12:08 PM
