transmission help
Old Dec 2, 2014 | 03:39 PM
bulldog88's Avatar
bulldog88
transmission help
I have a 2003. It is four wheel drive. The truck has about 403000 miles on it. If I don't let the truck warm up for 10 to 20 minutes depending how cold it is outside when I put it in drive it takes about 10 to 15 seconds or longer sometimes to actually go into gear. If I put it down in low it will go right into gear and I shift it manually up to drive. Once it is warm it shifts fine. Is this something that can possibly be fixed or do I need to start saving for a new one.
I do not tow trailer very much.
Old Dec 2, 2014 | 05:03 PM
Pitcrw6's Avatar
Pitcrw6
Automatic or manual? I dont know crap about trannys but there are some on here that know there stuff and need to know which one it is. I would say at that many miles on it, its time for a rebuild.
Old Dec 2, 2014 | 05:16 PM
tonym17's Avatar
tonym17
form his post looks like an automatic....
Old Dec 2, 2014 | 05:27 PM
bulldog88's Avatar
bulldog88
Its a automatic. I did fluid and filter change last week.
Old Dec 2, 2014 | 09:40 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It is possible that the feed bolts under the valve body have worked loose and are leaking. Most likely the seals are worn out in the forward clutch.
JKLman
1997 - 2003 F150
15
Jan 4, 2015 09:25 PM
ckellf350
2004 - 2008 F150
Nov 13, 2014 07:31 PM
Ford4-life
Apr 18, 2006 09:47 AM
niva
Aerostar
Sep 20, 2004 11:37 AM
Family Van
Aerostar
Apr 20, 2004 05:24 PM
