Options to fix radius arm rub?
Hello, i just put a 6" lift with some 35x12.50 15's on it, and it rubs on my radius arm at about one and a half wheel turn.
I know my options are to get wheel spacers, different rims or extended radius arms to fix this issue.
I need some opinions on what kind of rim/backspacing i need to purchase, or if i should just get some extended radius arms. Thank you for taking the time to read this post, i know it's a lot
Edit: 96 f150 4x4
Edit: 96 f150 4x4
Negative back spacing? No. That would mean the inner bead of the tire is outboard from the mounting surface. That would look... odd.
To the OP, If your stock tires were 235s, they were 9.25" wide. Going up to 12.5" wide tires on the same rims moves the inner edge of the tire about 1 5/8" in. My understanding is that factiory rims on these trucks were zero offset, so to move the inner edge of the tire to the original location you'd need about 1 5/8" negative offset. I've been told that offset is speced in mm, so that would be about -41 mm offset.
The only problem with that, is the only thing close to -41mm is -38mm on a 15x10. Not sure if that's going to help too much. I did find a website with extended radius arms for $490 after tax.
I would use wheel spacers, except I only have about 1 1/2" to play with before the hubcaps stick out further than the locking hubs.
btravis90
02-15-2012 12:17 PM
