Oil vs coolant numbers tell what u think
I have a 06 with 35k on the clock eot is 199-197 ect is 186-184 running 60 on cruse with 5-40 synthic oil 600 miles on it and elc coolant and filter with 4000 miles on it at 0 to-5 degrees with winter grill cover on truck is clean no oasis work or any aftermarket stuff bought it with 30k 3 months ago are the numbers bad or good ?
The Ford T-stat is what most run, despite it running cold again soon - for some.
With the Winter Front AND your very cold air temps - it's sort of hard to tell how those would effect your actual temps..
Hard to believe you only have 35k miles - you need to drive it more..
After sitting a day or so, before starting the engine - compare your ECT, EOT and TFT to verify your sensors are close to each other - and the outside air temp, before you decide to do anything - sometimes, the sensors are OFF and you replace parts with no effect..
There is an on-going thread about the Mishimoto 200 degree t-stat, it looked promising at keeping the temps up, but now a number of folks are having issues with fitment and/or temps falling even lower.. so there is no 100% clear winner. The Ford t-stat is cheaper and known to fit/work, but with your outdoor temps, you might do all the work and find nothing changed.. If you have a nice heated garage to work in, it might be worth swapping in a new Ford OEM.. otherwise, for 4 degrees I'd just deal with it until it's warmer outside.
036.0stroke
05-29-2016 09:57 PM
zettawatt
04-22-2013 11:26 AM
