What Should my ECT really be
Old Feb 16, 2011 | 07:08 AM
florida_1959's Avatar
florida_1959
Is there a guideline to use for understanding my ECT? I read a lot of posts on here that users have ECT's running around 190. I have an 06 with 116K miles and new EGR and oil coolers, coolant system flushed and coolant filter clean last two changes. The T-stat was new (OEM) and I run 197 when fully warmed up. Is this normal, what is the degree rating on the 6.0 t-stat.
thanks
Old Feb 16, 2011 | 07:25 AM
ljutic ss's Avatar
ljutic ss
When the coolant shows 197, what is the oil temp?
Old Feb 16, 2011 | 08:02 AM
florida_1959
oil temp runs 199 when coolant is 197. Just wondering why my ECT seems higher than most posts are reporting.
Old Feb 16, 2011 | 08:19 AM
Jakebrake's Avatar
Jakebrake
< Samantha...my Co-Pilot
I would say that your coolant temps are right where they should be.
Old Feb 16, 2011 | 08:43 AM
8lug's Avatar
8lug
My coolant temp runs 171 to 178 empty.
Old Feb 16, 2011 | 08:57 AM
broncoformudv's Avatar
broncoformudv
The thermostat should be 192-195, 197 is a little above what it should be but not a temp I would complain about or worry about. Just keep an eye on it.
Old Feb 16, 2011 | 12:26 PM
69cj's Avatar
69cj
To 8lug, If those temps are with the engine warmed up then you have a faulty t-stat. The stock t-stats are not fully opened til around 204. 197 is perfectly acceptable.
Old Feb 16, 2011 | 01:32 PM
dchamberlain's Avatar
dchamberlain
This is what Ford says about the thermostat. On a 6.0L, is should start opening between 188-196 and should be fully open at 219.
Old Feb 16, 2011 | 02:10 PM
i eat hybrids's Avatar
i eat hybrids
To the OP, whats the temperature outside when you see these ECT temps? On a cold day 0-20 degrees, my truck will reach 185 or so. On a warm day, 40 degree + itll reach 195. Thats after 15 mins of driving..
Old Feb 16, 2011 | 03:27 PM
florida_1959
I live in Florida, outside temp is 70ish this time of year, but I am thinking in the dead of summer at 85-90 I am going to see ECT well above 210 I am sure.
Old Feb 16, 2011 | 07:36 PM
moebdick's Avatar
moebdick
My ECT will span a 40 degree range, depending on the weather, my driving speed, how much I'm hauling/towing, etc. Temps of 210 F are fine if you're towing.
Old Feb 16, 2011 | 07:52 PM
2006lariat's Avatar
2006lariat
Towing my TT my temps have spiked to 228f. My oil always runs 5-7* warmer than my coolant, when working the truck hard. I got stuck in the snow and Ice this weekend, and admittingly, was being pretty hard on the truck, and saw in the 230's, than I remembered I had my rad blocked off, pulled the cardboard, and went back down to around 220.
O right now empty I am runnin from 179-196*f and my oil is within a few degrees of that! It has been in the teens here though, till tonight!
Old Feb 17, 2011 | 12:38 AM
8lug's Avatar
8lug
Thanks 69 I'll have to change that today.
Old Feb 17, 2011 | 10:25 AM
8lug's Avatar
8lug
This probably explains my fuel mileage dropping 2 MPG last summer.
