Minnesota Chapter Join Chapter, Leader: fordpower88
December - chattering teeth BS Thread
Old Dec 2, 2014 | 06:40 AM
  #31
HP junkie's Avatar
HP junkie
Good morning Randy and the rest of the crew!
Coffee is is on but no bagels or rolls or even donuts. I need to come to your house Randy.
Old Dec 2, 2014 | 07:44 AM
  #32
fordpower88's Avatar
fordpower88
Good morning Randy, Cory and the rest of the gang!
Have a great Tuesday everyone!
Old Dec 2, 2014 | 08:14 AM
  #33
Ford79's Avatar
Ford79
Good morning everyone.
Old Dec 2, 2014 | 11:22 AM
  #34
wildstang's Avatar
wildstang
VT Chapter Ldr
Good afternoon and have a terrific Tuesday MN and gang
Old Dec 2, 2014 | 11:23 AM
  #35
wildstang's Avatar
wildstang
VT Chapter Ldr
get that polaris running yet?
Old Dec 2, 2014 | 11:53 AM
  #36
HP junkie's Avatar
HP junkie
Running......yes. It won't start back up after shutting it off without starting fluid. Needs some carb adjustment. Had it driving around the yard but seems like the carbs would load up when idling. If it idled for a min and you hit the throttle it would bog and die. Had to feather it to get it to go but ran out nice and strong. Time to sync carbs and adjust them.
Old Dec 2, 2014 | 12:26 PM
  #37
Big-Foot's Avatar
Big-Foot
Have you cleaned or replaced the spark plugs?
My experience with 2 strokes is that if they take starting fluid to get going, the plugs are taking too much current to get a clean enough spark to start on plain fuel.. Might also be a coil or ignitor issue?
Plugs can be oily down at the base of the porceline which causes spark bleed-over.. I put them in a vice and spray the inside of the plug really good, with Gumout carb cleaner let it air dry, then use a propane torch on them to finish evaporating any oil residue..
It works for me anyway....
Old Dec 2, 2014 | 12:52 PM
  #38
HP junkie's Avatar
HP junkie
Brand new plugs. They are cheap so I replace every year to keep from having any issues.
Old Dec 2, 2014 | 12:58 PM
  #39
MisterCMK's Avatar
MisterCMK
Are the plugs wet when it won't start without snort?
Sent from my Telegraph using IB AutoGroup
Old Dec 2, 2014 | 01:18 PM
  #40
HP junkie's Avatar
HP junkie
I hope not cause i drove it around the yard for a few fast passes and so did her dad. when we parked it by the garage after it would not start back up right away.
Old Dec 2, 2014 | 01:19 PM
  #41
HP junkie's Avatar
HP junkie
Clever bastarrrrds!
Old Dec 2, 2014 | 01:31 PM
  #42
Big-Foot's Avatar
Big-Foot
Clever thief is more like it... I'd be shoving that truck up that dealer's nose... Or something else that smells....
Old Dec 2, 2014 | 01:36 PM
  #43
HP junkie's Avatar
HP junkie
Old Dec 2, 2014 | 02:33 PM
  #44
fordpower88
There is one way to make selling a 6.0 easier. LOL!! Hide the major problems with a tube of RTV silicone!
Old Dec 2, 2014 | 02:50 PM
  #45
Big-Foot's Avatar
Big-Foot
The general public will likely never be good owners / drivers of turbocharged vehicles.
They have poor maintenance habits and many times use the wrong or inferior oils..
But most importantly, they think they can just hammer the crap out of a turbocharged vehicle from sone cold up to max operating temperature, time and time again - and then pull off the freeway where they were running 85 mph and shut the engine down immediately. No cool down time. Heat soak issues and coking of oil is pervasive throughout all turbocharged engines that are treated in this manner.
The problem with the PCV inlet being close to individual cylinders is not an eco-boost only issue.. That inlet should be just down stream of the throttle body to get an even distribution of that oil vapor stream....
I swear that a lot of these so-called "engineers" were hatched out in the cold and lived under rocks until they grew up and went to do-do school....
