Correct Torque Spindle Nuts?
Old Nov 30, 2014 | 02:40 PM
veggietruckfarmer's Avatar
veggietruckfarmer
I have gotten many different answers (even found a few different ones on this forum haha) for exact torque specs/procedure for 95 f150 spindle nuts. I seated new wheel bearings with 30-40 lbs then retightened by feel to 17-20. But some say as much as 180 to seat and 60 retighten. Thoughts?
Old Nov 30, 2014 | 03:10 PM
Island Time's Avatar
Island Time
2WD or 4X4?
Old Nov 30, 2014 | 04:42 PM
veggietruckfarmer
Originally Posted by Island Time
2WD or 4X4?
4×4, sorry
Old Nov 30, 2014 | 05:00 PM
bashby's Avatar
bashby
I do all tapered roller wheel bearngs the same, trailer hubs, front and rear bearings on my 2 and 4x4 trucks, whatever. Just tighten it up good and tight while spinning it, back it off then snug it enough to take the play out of the bearing plus a little preload. Its really not THAT critical. Depending on what you are working on, you usually have to tighten or loosen it a little to get a cotter pin or something to line up anyway.
Old Nov 30, 2014 | 05:17 PM
veggietruckfarmer
The side with the new bearings is getting significantly hotter than the old side. Not too hot to touch, but definitely hotter. I am trying to figure out whats wrong.
Old Nov 30, 2014 | 06:06 PM
bashby's Avatar
bashby
Brakes dragging is my guess.
Old Nov 30, 2014 | 07:22 PM
Island Time
The Ford service manual for my 1990 says 20-30 ft/lbs for an F150. It may be different for your 1995.
Definitely look for a dragging brake caliper. If you're checking for heat by feeling the hub, try feeling the caliper as well. That should give you an indication of where the heat is coming from.
Old Nov 30, 2014 | 08:44 PM
Tedster9's Avatar
Tedster9
http://www.skf.com/binary/79-66360/457377.pdf
Has many applications, code letters for specific procedure. 1995 F150 included. The end torque value isn't going to be much, though if you tighten to 60 foot pounds it's gonna smoke those bearings guaranteed. You had it right the first time, spin the wheel a few times and seat the bearings well and back off till ~20 is perfect.
Old Nov 30, 2014 | 09:46 PM
Island Time
When seating the bearings you want to ensure that the wheel is continuously rotated as you apply the seating torque. If you don't do that the rollers will make an indentation in the race. (There's a technical term for the indents but I don't recall it.) While it can be done by one person, it's a lot easier to have an assistance for this step.
Old Nov 30, 2014 | 10:04 PM
Garage Rat's Avatar
Garage Rat
I too have never actually used a torque spec, same procedure as everyone else, spin wheel while tightening, back off , then gently turn down til nut resists.
One thing I learned was that once you eliminate your end play, you can make sure you didn't over tighten by using a flat bade screwdriver and apply downward or upward pressure on washer ,it should still be able to move just slightly, Iv never had a issue with this method.
Old Dec 1, 2014 | 07:08 AM
dixie460's Avatar
dixie460
Your 95 is probably the same as my 96.
The right way to do it is spin the wheel while tightening the nut up to 70 (yes seventy) ft-lbs. then back the nut off 1/4 turn, then torque it to 20 ft-lbs. That being said, you can just do it by feel as the guys have mentioned above. I've done that plenty of times on lots of my Fords and never once had a problem.
The outer lock nut is supposed to go to I think 150 ft-lbs but I never torque that one. Instead I just put my 1/2" Earthquake impact to it and let that tap on it a few times... probably a bit more that 150 ft-lbs that way but I'd rather be too tight than too loose. You won't hurt the bearings if you over tighten the lock nut, all it does is keep the preload nut from moving so you want it in there good.
Old Dec 1, 2014 | 10:28 AM
veggietruckfarmer
Thanks folks.
I'm pretty sure the brakes aren't dragging but I will make sure.
Do new bearings heat up more than old ones initially? I have heard that they do until they get excess grease out and "break in", but that doesn't make much sense to my brain. Seems there should be very little "break in" if seated correctly and the grease I would think would come out pretty quick.
Old Dec 1, 2014 | 10:56 AM
Tedster9's Avatar
Tedster9
Apropos of nothing, the bearing race and bearing is a set, and both should be replaced at the same time.
Old Dec 1, 2014 | 11:18 AM
Garage Rat's Avatar
Garage Rat
Are these manual or auto hubs?
Old Dec 1, 2014 | 11:28 AM
veggietruckfarmer
They are manual hubs.
blueeyedfordguy
1997 - 2003 F150
Sep 15, 2024 04:06 PM
fdude64
Aug 19, 2012 08:02 PM
Midnite1987
19
Jan 27, 2012 10:43 PM
Busa01
3.8 & 4.2L V6
20
Nov 2, 2004 08:40 AM
Jrock909
1978 - 1996 Big Bronco
Aug 13, 2004 09:38 PM
