70 amp Circuit Breaker
OK, so I have the C3TZ-14526-A 70 amp circuit breaker pictured below. Can someone give me some advise on the best way to mount this breaker on the inner fender? Also, confirm where in the wiring system does this breaker go.
Looking at the wiring diagram it appears the 8 gauge wire runs from the solenoid to the breaker from the breaker to the alt gauge and them back to the junction post with the yellow/black alt wires. Is that correct?
Thanks in advance! John
I don't like the way that the OEM circuit breaker will mount to the inner fender so I've been looking for other options. I'm considering this setup. Any opinions are appreciated.
CB185 Series Manuel Reset Circuit Breakers 12 volt to 48 volt.
Thanks John,
just what I needed! At this point I plant to just install the breaker using the brackets you see in the photo, unless someone provides a different mounting option. I'll also cover the screw connections on the rear of the breaker with some electrical tape since they will be close to the inner fender
johnmel59
Electrical Systems/Wiring
07-05-2022 06:01 AM
