70 amp Circuit Breaker
OK, so I have the 70 amp circuit breaker pictured below. Can someone give me some advise on the best way to mount this breaker on the inner fender? Also, confirm where in the wiring system does this breaker go.
Looking at the wiring diagram it appears the 8 gauge wire runs from the solenoid to the breaker from the breaker to the alt gauge and them back to the junction post with the yellow/black alt wires. Is that correct?
Thanks in advance! John
Still looking for some help on this.
Thanks, John
Thanks, John
Yes, but its an aftermarket breaker and mounts differently than the factory breaker. This is what the back of mine looks like.
In your recent thread 'alternator gauge wiring' member posted a pic of the fuse mounted on the inner fender.
https://www.ford-trucks.com/forums/1...ring-help.html
The fuse, or junction block, is installed in the circuit for the 'alt' gauge.
Thanks, here is a picture of what I currently have and the proposed wiring changes--essentially moving the end of the 8 ga wire from the junction post to one side of the circuit breaker and install a 8 ga jumper from the circuit breaker to the junction post. I WELCOME ANY feedback.
Thanks, John
Thanks, John
If understand correctly, replacing the current junction block, which would probably been okay, for a 70 amp fused block. Appears you are running the circuit similar to how I ran the 'alt' circuit. Posting pic of drawing another FTE member emailed. except the pic shows a junction block whereas I used a fused block??
Thanks, that is the wiring diagram I used fro wiring the ALT gauge. I don't plan to replace the junction block but install a circuit breaker in the wiring in effort to avoid a major issue if something unseen were to occur in the future.
Not that knowledgeable with automotive electrical circuits, just not sure how a junction block, and fuse block, that appear to be running in parallel, would work; seems only need one or the other, to my knowledge only used for the 'alt' circuit. I was not familiar w/ the alt circuit and felt comfortable with a fused as opposed to function. Imagine as long as your circuitry works and does not place the other circuits at risk then may not present a problem?? Perhaps other members will chime in??
Hello, again, Johnmel59. I hope I can help again.
Yes, this is the best way to install it.
Generally when working with circuit breakers, you want a breaker to be nearest the source of the electricity. Ergo, breakers in a house are right after the incoming wires. This will not only protect the device, but all the wiring between the breaker and the device.
Therefore, your breaker should be installed in series just after the battery source. So, this is how I would wire it:
1. Remove the 8 gauge wire that goes to the ammeter from the solenoid (the side with the battery cable).
2. Install this wire on one side of the breaker.
3. Install your short "jumper" onto the battery side of the solenoid, where the ammeter wire used to be attached.
4. Install the other end of the "jumper" onto the other side of the breaker.
That should do it. Wired this way (for example), should the wire between the breaker and the ammeter develop a direct short to ground by rubbing on a sharp metal edge, the breaker will pop and protect it from catching fire. Not only will it protect that one wire, but this setup will further protect the under-dash wiring from possible fire damage as well.
Hope this helps as well!
John (the other John)
.....confirm where in the wiring system does this breaker go.
Thanks John,
just what I needed! At this point I plant to just install the breaker using the brackets you see in the photo, unless someone provides a different mounting option. I'll also cover the screw connections on the rear of the breaker with some electrical tape since they will be close to the inner fender
