Fuel Leak
Old Nov 30, 2014 | 12:08 AM
MikePacey's Avatar
MikePacey
Fuel Leak
Alright guys I need help I'm pulling my hair out right now. I've got a 2004 F350 with the 6.0 and yesterday I did the blue spring upgrade kit with the regulator. Well I have a fuel line leaking on the upper filter housing where the back to fuel lines are located. I checked if it was loose and it was not. I can not find anything on the internet, google, here, or an auto parts store with the O-Rings for those two fuel lines. Does anyone have a part number or at least what the techinical name for the line o rings to look them up at a parts store?
Thanks in advance.
Old Nov 30, 2014 | 04:30 AM
Yahiko's Avatar
Yahiko
The banjo bolt one takes copper crush washers.
The cover O-ring comes in the filter change kit.
What lines are you having problems with?
Sean
Old Nov 30, 2014 | 06:52 AM
78fordman's Avatar
78fordman
Sounds like the supply and return lines. There are orings in the adapters threaded in the cover.
Old Nov 30, 2014 | 06:55 AM
dannyboy950's Avatar
dannyboy950
03-04 fuel lines
The 03-04 filter uses screw on fuel lines. Banjo fittings came out in 05.
Ford it seems thought thoes o-rings would never need changeing. I could not find any either. Finaly had to dig into my o-ring assortment and found some that would fit.
Only other option was new lines.
Sorry I had a picture but I can't get it to attach.
Old Nov 30, 2014 | 09:22 AM
MikePacey's Avatar
MikePacey
This is so frustrating, it's not a terrible leak but your finger will get wet if you put your finger on it at idle, which it's most likely worse under load. My biggest fear is it causing a lean condition and making a big old kaboom! I'm trying to rush to get this fixed before this coming weekend because I'm taking a 16 hour round trip to get a new race car.
Old Nov 30, 2014 | 09:49 AM
mustang_309's Avatar
mustang_309
It shouldn't get any worse under load as the highest fuel line pressure is at idle. You might try your local hydraulic hose shop to see if the have an oring that will fit.
Old Nov 30, 2014 | 09:56 AM
MikePacey's Avatar
MikePacey
Well my question is would anything they have be compatiable with diesel fuel?
Old Nov 30, 2014 | 10:33 AM
mustang_309
I'm sure they would have something, just let them know its for a diesel fuel line.
Old Nov 30, 2014 | 10:53 AM
dannyboy950
Most o-rings that I know of are compatible with diesel.
Old Nov 30, 2014 | 04:12 PM
Yahiko's Avatar
Yahiko
Buna-n or Vitron O-ring.
EDIT :
Here is a selection guide.
O-Ring Material Selection Guidelines, Information
The rubber ones will tend to swell.
Also when I got my kit from IH the O-rings
for the ends were in it with the other parts.
You did not remove the thread in adaptors
from the housing.
Sean
Old Nov 30, 2014 | 05:34 PM
mattdoc88's Avatar
mattdoc88
Obvious question maybe, but the blue spring kit comes with a bunch of o-rings... did you check if one of those will work? Or did you replace one with a new o-ring from the kit and that's the problem?
Old Dec 1, 2014 | 11:33 AM
MikePacey's Avatar
MikePacey
When I got the blue spring kit it just came with the nessasary O-rings for just the fuel pressure regulator and the fuel return line. It did not come with extras for the other two lines.
Old Dec 1, 2014 | 05:38 PM
Yahiko's Avatar
Yahiko
Can you post a photo of where you have the leak?
Sean
Old Dec 1, 2014 | 08:36 PM
woodlander's Avatar
woodlander
You can buy the orings separate. Fordparts.com has the blow up pic with part numbers.
sudsmcduff
Apr 5, 2016 02:36 AM
MikePacey
Nov 30, 2014 09:25 AM
Morton4763
Oct 13, 2010 10:59 PM
momsvan89
1983 - 2012 Ranger & B-Series
Aug 20, 2007 07:55 AM
ddetrick78
Apr 20, 2006 09:02 PM
