Electrical Gremlins
Old Nov 29, 2014 | 07:54 PM
Restlesswildman's Avatar
Restlesswildman
Cool Electrical Gremlins
I have been chasing an electrical gremlin since the spring time!
I had a bad injector in hole #5. Confirmed with a contribution test along with drivability issues! Replaced the injector and all was good except I was having phantom contribution issues. This was confirmed by myself and 2 garages. Contribution test and compression tests.
I have been getting from time to time bogus other codes for crank sensor and synch. Truck still starts and runs.
Fast forward to tonight. The kids and I went to check on my Mother's grave marker that was just set a week ago. As we pulled up to a light, I let of the gas and applied the brakes. The truck shut off like I turned the key off. Put it in neutral and it fired right up. Drove a few minutes down the road and pull into a parking lot. Put my AE on it and it has codes for #5 & 6 injectors. I clear the codes and drive home 45 minutes and check for codes. There were no codes at all!
So where do I go from this point? I have checked everything that I can. 2 shops have also. WE all agree that tossing parts is not a good idea. All connections have been checked a few times. Wiring harness does not show any visible chaffing. FLP, FMP and Alt voltage all are good on the Scan Gauge and verified with a multimeter. Batteries have not been checked because they do not drop under 11.5 when starting.
Is there anything in the FICM that could cause this issue?
Old Nov 29, 2014 | 07:58 PM
mustang_309's Avatar
mustang_309
Fast forward to tonight. The kids and I went to check on my Mother's grave marker that was just set a week ago. As we pulled up to a light, I left of the gas and applied the brakes. The truck shut off like I turned the key off. Put it in neutral and it fired right up. Drove a few minutes down the road and pull into a parking lot. Put my AE on it and it has codes for #5 & 6 injectors. I clear the codes and drive home 45 minutes and check for codes. There were no codes at all!
When it died did the glow plug light come on?
Old Nov 29, 2014 | 08:02 PM
Restlesswildman
All the idiot lights came on at once on the dash since it died. I didn't see the glow plug light come on before anything else.
Old Nov 29, 2014 | 08:32 PM
Yahiko's Avatar
Yahiko
Start watching the Vref.
Sean
Old Nov 29, 2014 | 09:14 PM
dannyboy950's Avatar
dannyboy950
How did you determin the cam and sync codes were bogus codes?
Old Nov 29, 2014 | 11:07 PM
Restlesswildman
Cleared em and they haven't returned in oh 7k miles.
Old Nov 29, 2014 | 11:09 PM
Restlesswildman
Sean
That is programmed in the scangauge as CVI correct?
Old Nov 29, 2014 | 11:13 PM
dannyboy950
May not have been bogus but a temporay loss of signal either way not germain to your problem I think.
Sorry I been up for too long getting a little punch drunk. Can't think clearly I don't want to missguide you. Gnite
Old Nov 30, 2014 | 12:13 AM
Yahiko's Avatar
Yahiko
You mean Xgauge? NOTE : Had not seen it called that before.
VREF
07E0221155
046245110655
3010
006433330000
notes : CVI Calibration Voltage Input
For more Xguages look here >>> Ford/Lincoln/Mercury Specific : Linear Logic : Home of the ScanGauge
Sean
Old Nov 30, 2014 | 01:13 PM
Restlesswildman
VREF
07E0221155
046245110655
3010
006433330000
Sean
That was what I wanted to verify! I already had it in the Scan Gauge. Flipped one of readouts to that this am. I saw it drop to 4 volts 3 times in a 2 minute drive. Any idea on what or were I need to start digging in at?
Old Nov 30, 2014 | 01:33 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Shot in the dark but I'd unplug the EBP sensor first and see if vRef stays steady at 5v or very near it. Being it's an '03 it may not run any different if it got the inferred EBP software update.
Old Nov 30, 2014 | 04:56 PM
Yahiko's Avatar
Yahiko
Rusty is right. We have seen a few of the EBP sensors give people fits.
Then after they unplug the silly thing the truck runs right. Then you
will know that it's the sensor/pigtail or both.
Sean
Old Nov 30, 2014 | 07:10 PM
Restlesswildman
Had the EBP sensor replaced in the spring when the WP pulley split in 2 and caused havoc! Supposedly the plug and harness were fine at that point.
This truck has done this twice to me in 2 years. Shut right of and restarted immediately. Both times in cold weather.
The ECM is what sends out the VREF voltage correct?
Old Nov 30, 2014 | 09:36 PM
Yahiko's Avatar
Yahiko
No I think that would come from the PCM.
It's not just a diesel thing.
Sean
fluidp
Mar 7, 2014 08:22 PM
Outrun Racing
Sep 28, 2012 09:45 PM
southernorpi
Jul 9, 2012 09:24 PM
Bucko1975
Jan 5, 2010 07:50 PM
Budlight592
May 15, 2009 05:49 PM
