01 Excursion running bad, has codes
Old Sep 28, 2012 | 07:08 PM
Outrun Racing's Avatar
Outrun Racing
was running fine, then about 15mins from work started losing power and felt like it was missing! On the way home same thing, but would come and go? Checked coeds with my scanner and heres what they were..
P1316 Injector driver codes detected
P0677 #7 glow plug
P0675 #5 glow plug
Wondering if you guys could give me a starting point on how to tackle this problem? Thanks for any help!!!
Old Sep 28, 2012 | 07:29 PM
BigAlsPSD's Avatar
BigAlsPSD
I would look into ohming out at least the passenger's side UVCH(Under Valve Cover Harness) this is where the wiring to the injectors and GP's pass through under the Valve Covers.
I say passenger's because of the odd numbers.
What are you using to pull the codes?
If you can do a BUZZ test, or KOEO you might verify with injector codes for the passenger's side bank.
Old Sep 28, 2012 | 07:38 PM
BigAlsPSD's Avatar
BigAlsPSD
Here is what can happen.
Ford Truck Enthusiasts Forums - View Single Post - Check your injector wiring!!!
And here is a thread with a solution known as the 50 cent mod.
50 cent mod for UVCH
Old Sep 28, 2012 | 07:49 PM
Outrun Racing
I'm using an Inova scanner, it can run a KOEO test i believe, ill run that tomorrow when I get off work, Thanks for the info and links... And that is exactly how my Excursion is running, so I imagine thats what I will find.
Old Sep 28, 2012 | 08:13 PM
1fixitman's Avatar
1fixitman
In short. The 50 cent mod is done to keep the Under Valve Cover Harness (UVCH) plugged in properly, clipped into place and a quarter(25 cent piece) placed under the plastic clip to keep it clipped. This is classic of the 7.3L problems. Now the details below. It KEEPS ALL INJECTORS and GLOW PLUGS plugged in and FIRING when necessary. You can be running on 3-7 cylinders based on wether the plugs under the valve covers are plugged in all the way or NOT. You can also have very hard starts from the glow plugs not being plugged in and only a few heating up.
You know I have to pop in here and ask if the Under Valve Cover Harness (UVCH) connector has been looked at and the 50 cent mod done? 50 cent mod video here
2001 F350 7.3L Turbo Diesel, UVCH - YouTube
How to do it written down from my post in another thread. The video above is not my video but is a great training tool.
For the 50 cent mod you will need two quarters, a short 13mm socket, deep 13mm socket and a universal or wobble short extension to get the back bolt on the drivers side and a few of the bottom bolts on the passenger side, a 13mm wrench and a long(6-8 inch) extension. Various wrenches and sockets for pulling harness connector and Intercooler boot clamps.
Only takes 20-25 minutes to pull the Turbo intake hoses and Turbo pipe(metal) on the driver's side. Be careful with the boots. Just be easy with them.
Don't pay too much attention to all the oil inside of the inlet tube and metal pipe as you can clean them any time IN THE FUTURE.
Right now focus on taking the valve cover off. I take out the stock filter and all the inlet tubing going to the turbo then I gently shove a not so good towel into the stock filter box AND lay a moving blanket( very thick folded over several times) over the battery and stock filter box so I can lay on it while I take the Valve cover bolts out. Be careful of the towel in the stock box for the sensor in that box. They are fragile. I am short so please laugh and work with me at the same time.
Unbolt the 42 pin electrical connector on top of the valve cover. If you have an air compressor, now is the time to blow any debris around the valve cover down out of the way.
Take a PICTURE or take note which fasteners are bolts and which ones are studs with a nut to mount something else to. You will want to put it back exactly as it was. Get the 13mm socket and a 13mm wrench.
DO NOT TAKE THE Positive Crankcase Vent or CrankCase Vent(CCV) DOGHOUSE OFF UNLESS YOU HAVE THE FOUR ORINGS TO RESEAL IT
4 Viton O-rings to reseal the Crank Case Vent cover
OR THE ORINGS WILL SWELL UP AND BE NO GOOD AND YOU WILL LEAK OIL ALL OVER THE PLACE UNTIL YOU GET THE NEW ORINGS.
Using the 13mm wrench carefully remove the bolt just above the CCV dog house and leave the CCV in place. You will not be able to use the socket with the CCV in the way. Now you can use that 13mm socket and take all the rest of the bolts out. The hardest one is on the rear of the cover and you can not see the bolt without a mirror. Don't worry about the mirror, just loosen it and place the bolts to the side. I use a 5 gallon pail to put my fastners in. Slow down when you get the bolts loose and keep a tight grip on them unless you like fishing for metal in the pit of hell. I put a tarp under the truck for items I drop to easily find them.
When you pull the cover loose, be slow and easy so you don't put any debris in the VC area. If your harness connection is loose, very gently push the connector towards the top of the VC gasket and let the clips clip UPWARD into place. You could also unclip it and inspect for burnt connectors. Place the connector back firmly in place. Now take the quarter that you have shaved off right at the top of the hair line on the head and slide it in round side down and flat, cut side toward the TOP of the valve cover. DO NOT FORCE ANYTHING unless you have a fresh Benjamin Franklin laying around to spend on a new gasket/harness.
The clips should be clipped fully in and pushing up whilist the quarter holds the clips up. The flat spot gives the valve cover enough room to be installed and keeps the quarter from going anywhere.
If you want to you can now check the torque on the:
Lower injector hold down bolts at 120 INCH lbs.
Rocker arm bolts at 20 Foot lbs
Valve cover bolts when reinstalled will be 96 INCH lbs.
Verify all of the injector connectors are secured and clipped
Verify all of the glow plug wires are tight.
Do everything in the reverse order to put it all back together. Wipe the oil coated pipes down to remove any excess oil and start on the passenger side
Remove the intercooler pipe. You will figure out that you have to move it above the turbo to get it out. Lots of room above that turbo. I loosened my boost pressure gauge and tied it back with string or a small bungee.
Bungee cord the two heater pipes toward the passenger side fender. I put the Moving blanket on this side but did not lean on the A/C pipes. Same thing on this side except you have a bolt holding down the Engine Oil Dipstick so be careful with the dipstick. Only pull the dipstick high enough to remove it from the stud. The bolt near the AC compressor is tight but you can get to it with a few extensions and a deep socket. Same one as the oil dipstick. Note the stud positions again. Don't loose the heater hose clips because they are 28$ at the dealer. Loosen and remove the rest of the bolt/studs. Same thing as the driver's side from here.
Man, that is a lot of typing. Talking thru it is much less time consuming. LOL. Put a wrench in your hands and get to work. The sooner you get it done, the sooner you can drink that favorite cold beverage and relax that another inexpensive mod is done and you will feel better for not spending any money at the mechanic shop or Stealership It might even run much better or have gained some power back. Same torque values as mentioned above. Be careful whilist VC's are open. If it rains you need to shut the hood all the way immediately after you remove the blanket and slowly slip the VC in place. I hope this helps and is not too mundane. I prefer air tools but you need to put it back together with regular rachet/wrench and get torque values correct.
Dwayne
Old Sep 28, 2012 | 08:21 PM
Outrun Racing
I have not looked at the harness, honestly I have just ran the scanner and posted on here, I wont have time to really do anything till next weekend, I just wanted to get a good starting point, and looks like I got it
Old Sep 28, 2012 | 09:45 PM
1fixitman's Avatar
1fixitman
At least you have over 25 post so if you want to upload pictures to photobucket and post the img link here then we will have pictures.
Dwayne
T-wood
Mar 3, 2019 01:58 PM
fluidp
Mar 7, 2014 08:22 PM
southernorpi
Jul 9, 2012 09:24 PM
1BADRIDE
Oct 2, 2010 11:26 AM
ZeroAccess
Sep 15, 2008 04:07 PM
