The long going gauges
Old Nov 29, 2014 | 05:34 PM
BigRick1979's Avatar
BigRick1979
I have searched and read up on the gauges threads on this forum for probably a few hours now. So glow shift is a no-no. You guys recommend automata or aspire. Now Which one is the best. I want something that is very accurate, durable. Price isn't and issue because $1,000.00 in gauges is cheaper than an engine. My buddy has an edge with attitude display that i thought about buying but i prefer the analog with digital displace (like the glow shift) I guess what do you guys mostly run. Id like it to have a warning light when get gets close to a programmable limit, boost to flash above a certain psi, and axle temp to do the same as egt. Any insight would be amazing thank you!
Old Nov 29, 2014 | 07:14 PM
BBslider001's Avatar
BBslider001
Glow Shifts are nice for the affordable price point. I just installed two in my truck in conjunction with my Edge Insight and they have been working just fine and look pretty good. If you have that much to spend, get Isspros and get as many parameters as you can. I would get EGT, fuel pressure, Boost, and Trans Temp for starters. If you have a manual, get an HPOP instead of the trans temp. Let us know what happens and take pics!!
Old Nov 29, 2014 | 10:41 PM
oldbird1965's Avatar
oldbird1965
Aeroforce Technology Inc | Products - Interceptor can read a lot of things for you, I really like mine. Isspro gauges are good also.
Old Nov 29, 2014 | 10:48 PM
BigRick1979
So the interceptor is one gauge but shows three other things?
Old Nov 29, 2014 | 10:58 PM
oldbird1965
It shows lots of things.
Trans temp
oil temp
DC% duty cycle
ICP pressures
Pluse width
boost
volts
what gear your in
etc.
Old Nov 29, 2014 | 11:38 PM
bryanlindborg600's Avatar
bryanlindborg600
Trans temp
oil temp
DC% duty cycle
ICP pressures
Pluse width
boost
volts
what gear your in
etc.
i've done a lot of things to my truck, this gauge is by far one of the best things i have bought! it does a ton, on top of whats listed above you can perform buzz tests pull and clear codes, it is a must have for any psd owner who wants to work on there own shint..unless you already have a high end diagnostic tool...
anyhow, good luck to the o.p
Old Nov 30, 2014 | 06:50 AM
1994F2507.3L's Avatar
1994F2507.3L
I run Autometer GS: Water Temp, Boost, Low Side Oil Press. and then the Edge Insight running EAS EGT, Trans Temp, Engine Oil Temp, Intake Air Temp, and Corrected Vehicle Speed.
Old Nov 30, 2014 | 09:20 AM
Thor'sHammer's Avatar
Thor'sHammer
I have two glow shift gauges, trans temp and boost. My EGT gauge is a digital cyberdyne unit that seems to be a whole lot better than my previous glowshift EGT gauge. I question the accuracy of the trans temp gauge sometimes and have replaced the sender twice. It's also hard to gauge the actual temp as it has markings in erroneous locations between temp markings (like 150| | |170||| |210||||||230||260).
Old Nov 30, 2014 | 09:23 AM
oldbird1965
Besides the aeroforce scan gauge I have a boost gauge, 2 EGT gauges, fuel pressure, oil pressure, coolant temp (scan gauge will not read coolant temp) and coolingmist controller for water injection.
Old Nov 30, 2014 | 09:30 AM
madMatador78's Avatar
madMatador78
I have the autometer sd factory look alike gauges. They were there when I bought the truck,and that was a year and a half ago,they work great. I have trans temp, boost and Pyro. I've heard the isspro ones are good as well.
Old Nov 30, 2014 | 07:23 PM
Mike Bartlett's Avatar
Mike Bartlett
So I would assume the AeroForce Interceptor can't read EGT's? Also do you that have this gauge do you have 1 or 2 of them and what is the advantage of having 2?
Thanks...
Mike
Old Nov 30, 2014 | 07:36 PM
oldbird1965
Mike, I have two EGT's for two reasons. My autometer that I first installed started acting up, only works when it feels like it. I wanted to monitor both sides any way so I put a Isspro EV2 on the passenger side. When the autometer works, they both agree with one another so I'm not going to replace the autometer yet.
Old Nov 30, 2014 | 10:06 PM
LeoJr's Avatar
LeoJr
The Interceptor can read EGTs with an additional sensor. A sensor you would need (but may be included) with a dedicated EGT gauge.
The Interceptor can read two analog inputs (or sensors). Like EGT and fuel pressure, or diff tempt, etc.
It reads the engine oil, auto trans and intake air temp from the OBD port.
It also reads the MAP sensor for boost but I think digital numbers are harder to follow than an analog boost gauge. An analog boost gauge (in my mind) is a must if you want to watch it.
Here's mine in a SD column pod... It fits OK as is, but I made some minor mods to the pod for additional shifter clearance.
Old Nov 30, 2014 | 10:13 PM
LeoJr's Avatar
LeoJr
Bryan, may I start a new thread and use your post as the first entry?
I have an AutoEnginuity and the Interceptor. I'm having a hard time justifying my keeping the AE as I've only found one possibly helpful thing it does that the Interceptor doesn't.
Threadjack over...
Old Dec 1, 2014 | 09:51 PM
oldbird1965
I just thought I would add this to a 'gauge' thread. Over the weekend my Isspro fuel pressure gauge quit. I checked all my wiring and did continuity check on them and all was good. I called Isspro and she asked if my sending unit was chrome or brass. I told her brass and she said they were having problems with them and she would send me a new one. One stipulation, I would send in the brass one. I said sure! Love it when you get good service. I had the gauge for all most two years.
Gear619
Dec 28, 2015 08:55 PM
oldkountryboy
Feb 22, 2014 06:26 PM
Kingkoopa
Feb 4, 2014 04:40 PM
73cntry
Oct 4, 2008 03:55 PM
Duck Hunter81
13
Sep 5, 2008 02:03 PM
