can someone tell me how much wider the front axle is than the rear axle on my 72 f100? I want to add some spacers to the rear that will allow the tires to track on the same path.
Reason: explanation
I am using 15X8 rims, planning on running 10" wide on Front and 11" wide on rear. would you suggest running 2" spacers on each side? and thanks for the info.
I think you'll have trouble getting 11s to fit on the back, unless the offset is perfect.
The rear wheel well is about 13.25 inches wide.
Is the 11-inch width you're referring to is the tread width? You'll need to account for the sidewall bulge - the section width.
The rear axle on my 67 f100 is 60 inches wheel mount surface to wheel mount surface. In the past, I used a 1.5 inch spacer on each side to get it more visually in line with the front.
