F100 Rear axle selection
I have just bought a 1975 F100, the problem is the ford 9 inch rear end is gone, but there is an Jeep AMC 20 CJ6 rear axle bolted to the leaf springs, but this axle is not wide enough it measures 58.5 inchs WMS to WMS but i think it needs to be approx 8 inches wider.
Can I make up the difference using 1.5 inch wheel spacers and wider offset rims or should I try and source a wider axle.
I'm in the UK and ford 9 inch axles are rare, most of them are on the back of drag cars.
Thanks in advance
<!-- / message -->
Thanks in advance
<!-- / message -->
I thought about your problem after my first post and have another suggestion.Since you are in the UK , shipping from the states will be a lot. You might be able to use a later F series rear that are not 9 inch. The main problem other than finding one would be they may be too wide unless you have a flat bed on your truck. Thats the best I can think of right now,there may be some other rears that will work that somebody will help you with.
F350moneypit
17
02-27-2019 12:01 AM
jamesadams
06-23-2012 06:20 PM
jaydubya
01-05-2011 11:46 AM
