axle width
Old Nov 29, 2014 | 11:02 AM
ranwilmcc's Avatar
ranwilmcc
axle width
can someone tell me how much wider the front axle is than the rear axle on my 72 f100? I want to add some spacers to the rear that will allow the tires to track on the same path.
Old Nov 29, 2014 | 11:27 AM
351Cleveland C4's Avatar
351Cleveland C4
I think it's 3" but I'm not certain.
Old Nov 29, 2014 | 11:55 AM
JEFFFAFA's Avatar
JEFFFAFA
Welcome to FTE newbie!
I used the search engine above and found where HioSilver said the rear is 2" narrower recently.
Old Nov 29, 2014 | 12:11 PM
HIO Silver's Avatar
HIO Silver
To clarify it's two inches on each side:
61.25 inches 1957-1972 Ford F-100 Pickup
65.25 inches 1973-1986 Ford F-150 Pickup
Rear End Widths
To visually correct, spec rear tires that are two inches wider than the front tires with proper wheel offset of course.
Old Nov 29, 2014 | 12:22 PM
ranwilmcc's Avatar
ranwilmcc
I am using 15X8 rims, planning on running 10" wide on Front and 11" wide on rear. would you suggest running 2" spacers on each side? and thanks for the info.
Old Nov 29, 2014 | 01:59 PM
351Cleveland C4
I think you'll have trouble getting 11s to fit on the back, unless the offset is perfect.
Old Nov 29, 2014 | 02:13 PM
HIO Silver's Avatar
HIO Silver
The rear wheel well is about 13.25 inches wide.
Is the 11-inch width you're referring to is the tread width? You'll need to account for the sidewall bulge - the section width.
Read this: Performance Wheels And Tires Fitment Guide - Car Craft Magazine
And this: How to Measure for Bigger Wheels and Tires - Size Matters
Old Nov 30, 2014 | 08:30 AM
f100today's Avatar
f100today
The rear axle on my 67 f100 is 60 inches wheel mount surface to wheel mount surface. In the past, I used a 1.5 inch spacer on each side to get it more visually in line with the front.
jrockdiddy
May 22, 2013 12:36 AM
axbreck
Nov 2, 2010 03:10 PM
scroller bill
1978 - 1996 Big Bronco
Oct 31, 2006 09:44 PM
bigblocksix
Offroad & 4x4
Dec 8, 2004 10:46 AM
bigblocksix
Dec 7, 2004 06:01 AM
