Brake change tools
Old Nov 29, 2014 | 02:48 PM
KDAVID1's Avatar
KDAVID1
Originally Posted by cheezit
There all metric. Have you tried a 16 mm on the 5/8?
I did (at my father in laws) probably a cheap socket.
2006 F350 4X4
Old Nov 29, 2014 | 02:57 PM
KDAVID1's Avatar
KDAVID1
Well half the job is done. Got the pads on both sides. The driver side disc had SO much corrosion from the wheel even a chisel wouldn't break it loose. The passenger side didn't have the corrosion on the disc but was locked solid. Now for the good part disc are good and pads were all I needed. The amazing part is I've got 146+k on the truck and this appears to be the first time the brakes have been done--simply amazing. I did find that both axle seals are popped out??? Never seen that happen before. I'll have to take it somewhere to break the disc loose at some point but for now I'll say the job is done. Oh once I figured out the disc weren't being changed it took about 10 minutes per side. I'll b post some pics when I get to the house.
2006 F350 4X4
Old Nov 29, 2014 | 02:58 PM
MisterCMK's Avatar
MisterCMK
Are you talking about the dust seal on the end of the axle tube?
That is normal for them to be popped out if it isn't the update style seal.
Old Nov 29, 2014 | 02:59 PM
KDAVID1's Avatar
KDAVID1
Originally Posted by 69cj
Drinking beer while doing brakes sometimes isn't good! I wait till after the test run, then it's Nellie bar the door. LOL
Yeah really only took a sip until after I took the test run. I don't drink much so you could tell this was a pia
2006 F350 4X4
Old Nov 29, 2014 | 03:00 PM
KDAVID1's Avatar
KDAVID1
Yeah That is probably what it is. I would have gone and changed them if I could have gotten the disc off.
2006 F350 4X4
Old Nov 29, 2014 | 03:27 PM
MisterCMK's Avatar
MisterCMK
2006 F350 4X4
I wouldn't do anything with it until you do ball joints and have everything apart already. The knuckle seal isn't cheap
Sent from my Telegraph using IB AutoGroup
Old Nov 29, 2014 | 03:39 PM
KDAVID1's Avatar
KDAVID1
Good idea. So far everything was tight as a drum. I was figuring to have a bunch of slop with the weight off but couldn't move a thing.
2006 F350 4X4
Old Nov 29, 2014 | 03:47 PM
KDAVID1's Avatar
KDAVID1
Was too po'd and didn't get a pic of the corrosion on the driver side disc/hub but this was the wheel studs
This is what I had to used to break the lugs and the caliper carrier bolts
Passenger side--no corrosion
The corrosion on the driver side was ALL from the aluminum wheel against the steel of the hub and disc.
2006 F350 4X4
Old Nov 29, 2014 | 04:08 PM
Yahiko's Avatar
Yahiko
Ball joints are on my to-do list. But not to the NOW list. The driver
side pad is no the NOW list in the next few weeks. I just hope I don't
have to add a set of rotors to that list. I know that they have been
once already and hope that there is enough meat left for at least one
more trip to the machine shop to true them up. Don't have any warpage
that I can feel but you never know and it all depends on how aggressive
the last turning was. So I'll just budget in 2 rotors and 2 calipers long
with pads and hardware. Oh yes and the credit card for all the parts.
Sean
Old Nov 29, 2014 | 05:00 PM
KDAVID1's Avatar
KDAVID1
I'll be taking the disc I bought back since I don't need them. I figure I have a couple more years on em which is a good thing.
2006 F350 4X4
Old Nov 29, 2014 | 05:49 PM
KDAVID1's Avatar
KDAVID1
You may find this hard to believe but as a mechanic being of a smaller frame size person is very advantageous. Im 5'6 and around 150.
I did find fighting with transmissions was the only issue, the jacks and benches are to tall
Haha--you got me by 2 inches my biggest issue is reach--mine is pretty short.
2006 F350 4X4
Old Nov 29, 2014 | 07:05 PM
BLADE35's Avatar
BLADE35
You need to invest in an impact gun lol
The ball joints on mine was a **** I had to use all kinds of pullers and crap everything was rusted and seized together pia would have been easy
I smeared a couple tubes anti seize on it going back together. Should be easier next time
Old Nov 29, 2014 | 07:17 PM
  #28
KDAVID1's Avatar
KDAVID1
You got that right. My compressor is down blew the adjustmemt valve and haven't replaced it yet. That's one of the things I hate about the first time tearing into this stuff. It's always a pain. Like you do as well I slather on the anti size and it's a breeze after that. Not looking forward to when I have to change ball joints and such if these discs are any indication of how tough it will be.
2006 F350 4X4
Old Nov 29, 2014 | 07:39 PM
  #29
BLADE35's Avatar
BLADE35
Yep right from the start I couldn't get the discs off
Fun times lol
Iirc I was like 600 bucks into ball joints with parts and all those special pullers seal drivers etc
Old Nov 29, 2014 | 08:02 PM
  #30
KDAVID1's Avatar
KDAVID1
Fun times lol
Hate it when that happens!!! Where the disc seated on the hub it looked like the worst corroded battery you had ever seen. I swear other than a battery I have never seen anything like it. I tell ya it's got to be bad if I give up on it lol.
2006 F350 4X4
