High Octane gas/timing?
Old Dec 1, 2014 | 10:50 PM
  #46
orich's Avatar
orich
Originally Posted by ultraranger
In overly simplified terms, an engine is just a glorified air pump. An air charge and fuel mixture are introduced, compressed, ignited and then expelled as exhaust, --repeat process.
Advancing/retarding the cam or advancing/retarding the distributor doesn't change the compression ratio of the engine. It only alters the timing event of when the air/fuel mixture is ignited.
The only way to increase the compression ratio of the engine is to change/mill the heads, install thinner head gaskets, install flat top or pop up pistons or, any combination of these.
If my '03 Mach 1 didn't have a high compression ratio, I wouldn't pay to put high octane fuel in it. The 240 in my '69 F-100 definitely doesn't get high octane, since it's a low compression engine and high octane fuel would just be an extra expense for no advantage in it.
But, if someone feels like high octane fuel in their low compression engine is doing wonders for it, put that more expensive magic motion lotion over in it.
Aw then your vehicles are a no brainer when it comes to selecting fuel grades..
orich
Old Dec 1, 2014 | 11:51 PM
  #47
Tedster9's Avatar
Tedster9
Somewhere on the web was reading a neat scan of some old auto repair article, think it was originally from the 1930s and they were complaining that "Gasoline quality has declined greatly since the 1920s" hm.
Old Dec 2, 2014 | 05:29 PM
  #48
CougarJohn's Avatar
CougarJohn
Ted, "Gasoline is not oil as such but has some lubricity..."
Funny, my son and I tore down his 351W a month ago. Four cracked pistons on the bottom side of one bank. Gasoline leaked out of the carb, washed the gasoline off the rings, cracked pistons and rings.
Not much lubrication there.
Old Dec 2, 2014 | 06:52 PM
  #49
351Cleveland C4's Avatar
351Cleveland C4
Gas is slipperier than alcohol though.
Old Dec 2, 2014 | 07:06 PM
  #50
Tedster9's Avatar
Tedster9
Yes. Injectors don't like E85 much? That's what I meant.
Sorry about your son's engine. Float problem?
BLackFenton
1997 - 2003 F150
Oct 6, 2006 05:54 PM
Ranch57
16
Feb 10, 2006 10:12 PM
78bigunns
Jan 12, 2006 07:34 PM
Pablo-UA
Aerostar
27
Jan 10, 2006 02:45 PM
jj292
Dec 17, 2003 09:10 PM
