P0269 code...
Old Nov 26, 2014 | 01:47 PM
happscrap's Avatar
happscrap
P0269 code...
Cylinder 4 contribution / balance
Not sure what it all means but i have a feeling it sounds like a injector might be bad.
As some of you know. I just recently bought this truck. Done a ton of stuff in the last week. First real run after all repairs and maintenance. Was on the highway coming home from the tranny flush service and ran a scan...P0269 came up.
Any suggestions on what I should do next.
98k on truck. Running t6 oil with arcoil.
Thank you all.
Old Nov 26, 2014 | 02:47 PM
jsm180's Avatar
jsm180
p0269 is #3 cyl, p0272 is cyl #4. It would suck to tear into the wrong side of the engine.
Old Nov 26, 2014 | 03:16 PM
happscrap's Avatar
happscrap
Hmmm .. maybe I wrote that down wrong. I cleared the codes. I'm sure it will come back. Lol
Would that be an injector? Or a bent pushrod?
Old Nov 26, 2014 | 03:50 PM
mustang_309's Avatar
mustang_309
It could be either but I would clear it and see if it comes back. You would notice a dead injector. If it feels like its running good with no rough idle I wouldn't worry about it unless it returns.
Old Nov 26, 2014 | 05:04 PM
happscrap's Avatar
happscrap
Yea...I cleared it. Then took the truck for a power tset ride. Truck runs and idles great. Once in a great while.. I think I hear a small.. tiny studder per say. Really got to be paying attention to hear it. Keep in mind 2 that I just purchased the truck and it has been sitting. I've done a ton of work to it including t6 oil with arcoil. I'm also running Lucas fuel injection cleaner. Hoping this will clean up the injectors... hoping.
Old Nov 26, 2014 | 05:59 PM
mustang_309
Just make sure the lucas product does NOT contain alcohol as this can cause water to go into solution and end up at the injectors which is one way injectors fail by way of the injector tip cracking from water in the fuel.
Old Nov 26, 2014 | 06:14 PM
happscrap's Avatar
happscrap
Ohh crap.. didn't know that .. Thank you. What product would you recommend? I know arcoil makes a fuel additive. I'm really happy with their oil side stuff.
Achen
6.7L Power Stroke Diesel
22
Jun 9, 2019 06:36 PM
kper05
16
Mar 16, 2018 09:33 PM
the_auto_tech
Mar 4, 2014 10:45 AM
clinter36
Sep 18, 2009 12:55 PM
powerman01
Jan 23, 2009 10:38 PM
