Electrical demons
Old Nov 26, 2014 | 12:04 AM
Larry Pederson's Avatar
Larry Pederson
Angry Electrical demons
Battery goes dead sometimes. Now the heater motor quit sometimes the head lights stay on, it driving me crazy
Old Nov 26, 2014 | 07:09 AM
P.Bronner's Avatar
P.Bronner
That sounds like a textbook loss of ground issue. Try running a temporary large gauge wire [10] from the negative post to the truck body and see if the problem goes away. Also follow the main ground cable to the engine block and inspect/tighten that connection. I've also encountered the situation where the cable looks good but has corroded inside the eye or terminal end fitting.
About 25 years ago I had a 72 Monte Carlo that developed an electrical issue. Everything was OK until the headlights were turned on. At this point the gas gauge went to empty, the turn signal arrows lit up and the high beam indicator worker backwards. In this case the dash panel had lost ground and a wire to the firewall fixed it.
jrotten67
Mar 20, 2017 12:09 AM
PRIMERED79 SHORT BED
Aug 14, 2016 10:12 PM
96B4000
1983 - 2012 Ranger & B-Series
Jul 30, 2010 02:30 PM
89Bulldog
Jul 28, 2010 09:01 PM
rondog66
Electrical Systems/Wiring
Jul 23, 2008 10:40 PM
