Dash light disco
It's possible that your battery ground cable runs to the engine block, which would require another cable between the block and cab - usually a short uninsulated braided flat cable running from a bellhousing bolt to the firewall. So make sure that your cab is indeed grounded as described. (Battery can ground to cab, and then from the cab to the block - but you'll need a fatter cable between the cab and block, to handle the starter's draw.)
Also check your headlight and tail lamp grounds - one at each corner of the vehicle. Heads readily visible under the hood, and tails inside behind the lamp assemblies, IIRC, so you'll have a little work to get to them.
If these check out OK, make sure you have a good ground to the gauge cluster. I think it comes in through the main harness, but hopefully someone will verify for sure. Find the ground wire, and test it's Ohms between the battery ground maybe?
Is the light switch loose? Not sure, but if it needs grounded to the cab and isn't, that that might cause some problems as well.
Make sure your steering column, mainly the turn signal switch, is/are grounded adequately as well.
Had you done anything which might've jostled any wiring in any of these areas lately?
Also, check any trailer lighting harnesses which might be on there. Those are often a hack-fest from what I've read...
