Sponsored by: Real Truck
fuel pump issue
Old Nov 25, 2014 | 06:55 PM
xfrog's Avatar
xfrog
fuel pump issue
Truck is a 2001 f350, V10, 4x4. Having intermittent starting issues, checked all the relays including the ones located behind the dash near the radio. Can't find anything wrong on that part. Issue may be temp related, seems to act up when it's cold out, less than 40 F, but that may have nothing to do with it. One thing that seems to effect the issue is the igntion switch/key, sometimes turn the key and you can hear pump kick on and prime, may work several times in a row, pull key out, re insert, turn it and pump won't kick on, giggle key, turn on/off a few times and pump starts kicking on like it's supposed to. I guess question is, is there something in the ign switch that could cause my problem, it sure seems like it.?
Old Nov 25, 2014 | 07:08 PM
r2millers's Avatar
r2millers
Your fuel pump only works in the start position, and then the run position but only when the engine has fired.
There is a fuel pump relay that actuates the fuel pump and the ecu needs to determine the engine is operating in a split second to keep the fuel pump operating. A safety factor.
You might first check the relay, then the fuel filter to ensure no obstruction, and then finally the fuel pump.
Not sure how many miles but if these guys are driven with 1/4 tank or lower regularly, I'd expect 125-150k miles before failure.
Old Nov 25, 2014 | 07:36 PM
xfrog's Avatar
xfrog
it's really acting like the switch is involved in the problem. I checked the relays, they bench test fine. I'm doubting it's a pump problem, when I turn the key I can hear if the pump kicks on/primes, if it primes it starts and runs fine, if I don't hear the initial prime it will crank but not start, turn the key off, giggle the key, try again and it will work almost every time. Sometimes it will prime, sometimes it won't, the ignition key/switch seems to be a contributing factor.
Old Nov 25, 2014 | 08:24 PM
EXv10's Avatar
EXv10
Can't help you you won't include the miles in your file.
Old Nov 25, 2014 | 09:21 PM
xfrog's Avatar
xfrog
miles on the truck, is that what your asking?
Old Nov 25, 2014 | 09:39 PM
EXv10's Avatar
EXv10
Yes, it helps with diagnosing but when people leave it out, well...............
I never could figure out why they won't post it.
Old Nov 25, 2014 | 10:56 PM
r2millers's Avatar
r2millers
If the ignition switch turns over the engine, the contact point is okay in the starting mode. You don't have different wires running directly off of the switch to allow it to turn over, yet not allow power to the fuel circuits.
I don't believe the ignition switch is the culprit.
Old Dec 3, 2014 | 06:53 PM
xfrog's Avatar
xfrog
ok, here is what I've found. From a wiring diagram I traced the fuel pump circuit to the inertia switch behind the pass kick panel. The diagram shows a pink/black stripe wire leaving the inertia switch going directly to the pump. I tapped into the p/b wire with a 12v test light. Every and I mean every time I turned on the ign switch, the light would light up for a short time and then go out. I assume the short time on was indicating the short time the pump should run to prime the system. Even though the light came on every time, I did NOT hear the pump prime every time, sometimes it did, sometimes it didn't. when I would hear the pump prime I went ahead and started the engine and the light stays on til I turn the truck off. This is telling me the pump is faulty, correct? I'm having a hard time understanding why the pump will kick on at one time and then not the next, I thought it would either work or it wouldn't? Tomorrow I'm going to try tapping into the pink wire back where it goes into the tank to see if I get the same results. Also, does anyone know where the "ground wire" connection is located for this fuel pump circuit?
Old Dec 3, 2014 | 07:04 PM
redford's Avatar
redford
FTE Leadership Emeritus
Have you put a fuel pressure guage on it yet? If there is sufficient fuel pressure in the fuel rails, I didn't think the pump would kick on when you tuned the key on.
Old Dec 3, 2014 | 07:31 PM
r2millers's Avatar
r2millers
The light stays on because the fuel relay recognizes engine spark and continues to operate until turned off. If you are getting an intermittent working pump, chances are that's the issue.
Fuel pumps operate with an electric motor attached. The brushes on these motors do start to create an intermittent contact with age. When cold, they tend to work but once warmed with internal friction, the brushes can fail and the pump stops working.
Not too uncommon to get this symptom and leave you sitting on the side of the road.
Alternators will do the same thing. You start up and the dash gauge looks like all is working properly. Once you get going, the alternator brushes again fail and once the battery is drained, there you go again, sitting.
You can carefully over ride you system with a portable battery and two contact wires to ensure it's working without the relay. Once connected, you can test your pressure at the fuel rail too.
Old Dec 3, 2014 | 07:50 PM
xfrog's Avatar
xfrog
Thanks for the reply.
Mine has done the opposite, acted up in the spring, worked fine once the weather warmed up, and recently started acting up as the temps have dropped into the 30's.......go figure.
I plan to try and and just isolate and power the pink wire back to the pump tomorrow and see if it will run every time power is applied.
to top it off, the tank is FULL, which will make it even more fun to remove.
Old Dec 3, 2014 | 07:56 PM
r2millers's Avatar
r2millers
I'm really referring to the start and stop cycles, regardless of outside temps.
Putting an in line pressure gauge in place is the simplest way to identify pump pressure. Do that before dropping the tank. Way too much effort.
drad
19
Jan 17, 2013 12:27 PM
wilsonjoey22
Oct 18, 2009 08:15 AM
1 good old boy
1997 - 2003 F150
Apr 17, 2006 07:41 PM
treblehook
Oct 1, 2003 10:11 PM
BWF_1
1983 - 2012 Ranger & B-Series
Sep 8, 2003 10:05 PM
