trying to use a code reader
Old Nov 24, 2014 | 05:02 PM
Daltongang's Avatar
Daltongang
I got a code reader hook up to my 94 f150 4wd 302 and iam doing a koeo test and I get a 111 followed by a 10 followed by a 121,122,123,124,157,172,173,327,628 and so I do a koer test and the first number for the cylnders is a 6 shouldnt it an 8 for a v8 does this mean I have 2 dead cylnders but then the numbers after that are 172,538,536,632,172,538,536,632 can anybody tell me whats going on with my engine?
Old Nov 24, 2014 | 06:40 PM
subford's Avatar
subford
I would pull the PCM Computer and open it up. Sounds like you may have lost the 5volt power supply (bad caps).
Old Nov 24, 2014 | 07:27 PM
Daltongang's Avatar
Daltongang
how do you do that subford?
Old Nov 25, 2014 | 07:03 AM
subford's Avatar
subford
What, pull the computer out?
If so remove the screws from the drivers inter fender, pry it open with a broom stick.
Then back out the bolt in the center of the computer plug with a 10mm 1/4" drive socket and remove the plug. After that remove the two screws above and below the computer plug and pull the computer out through the gap between the inter and outer fender.
I also like to block up the truck and take the front drivers wheel off.
Once the computer is out remove the screws from its case and look for deformed caps, traces ate through by acid or burnt items on the board. Also see if it smells burnt.
91CavGT
Jan 2, 2014 01:37 PM
Revmitchell
Jun 8, 2012 05:29 PM
tubss76
Apr 18, 2010 10:54 PM
EgoMan
Jun 23, 2006 05:38 PM
rockfiv0
Computer Chips & Tuners
Jul 11, 2002 09:08 PM
