Computer Chips & Tuners
A little help please...
Old Jul 10, 2002 | 10:51 PM
rockfiv0's Avatar
rockfiv0
I have a 2001 Ford F-250 Superduty with a 5.4L gas engine. I want to purchase a Diablo Chip for the truck, but here is my problem. I am unable to obtain the ECU code on my truck. I followed the directions about removing the two 7mm screws and tilting the unit to the left and reading the numbers off of the back of the unit. The problem is, when I remove those two 7 MM screws, nothing happens! Can somebody please give me some direction here?????
Old Jul 10, 2002 | 11:29 PM
FTE Ken's Avatar
FTE Ken
In the engine compartment, remove the 10mm bolt from the computer connector where the computer sticks through the firewall. Then pull out the computer. Disconnect the battery and do not have the key in the ignition when you do this. You'll find the code on the computer and connector.
Old Jul 11, 2002 | 09:08 PM
FTE Ken's Avatar
FTE Ken
