Computer location
Old Jun 23, 2006 | 03:16 PM
EgoMan's Avatar
EgoMan
Computer location
Where can I find the Computer location, and what does it look like on a 92 f-150? Also what does the "catch code" look like?
Old Jun 23, 2006 | 04:32 PM
EPNCSU2006's Avatar
EPNCSU2006
The computer is behind the drivers side kick panel, but it is accessed through the engine compartment. It has a long 60 pin connector attached to it down near the back of the left front wheelwell. The connector is held to the computer with a small screw with a 10 mm hex head on it, then the computer is retained by two more screws, but I'm unsure of their size. The catch code is on a label stuck to the plastic shield around the pins on the computer. It will most likely be a 4 character code and will be the biggest print on the label. Check out fordfuelinjection.com for an example of what the catch code looks like.
Old Jun 23, 2006 | 05:09 PM
EgoMan's Avatar
EgoMan
I think I know what your talking about....Ill have to go out and check it out now. I read it was under the passenger seat or behind the instument cluster.....thats what chiltons said anyway. so drivers side....i know my access port is there so I should just trace the wires back and it will be there?
Old Jun 23, 2006 | 05:38 PM
EgoMan's Avatar
EgoMan
ok roger that found it right under the booster....thanks bud.
