Please help decifer codes
Old Nov 21, 2014 | 11:29 PM
crazy96863's Avatar
crazy96863
Hey everybody. I'm helping a friend that is having issues with his 2001 explorer. It is a 2 Wheel Drive with a 4 L V6. It has an automatic transmission. I don't have a whole Lotta background on this vehicle as I've never driven it but I do have the codes.
P1309
P0320
I'd appreciate it if y'all could give me some direction as to where I should start diagnosing. Let me know what other information would be useful and I'll get back to you ASAP. Thank you.
Old Nov 23, 2014 | 11:30 AM
shorod's Avatar
shorod
P1309 - Misfire Monitor Disabled
What it means:
When the misfire monitor is disabled, usually due to the input signal generated by the camshaft position (CMP) sensor, by sensing the passage of teeth from the CMP wheel.
Possible causes:
  • Camshaft position sensor
  • Powertrain control module
  • ECT, MAF, and CKP sensors
P0320 - Ignition Engine Speed Input Circuit Malfunction
What it means:
The ignition engine speed sensor input signal to PCM is continuously monitored. The test fails when the signal indicates that two successive erratic profile ignition pickup (PIP) pulses have occurred.
Possible causes:
  • Loose wires/connectors.
  • Arcing secondary ignition components (coil, wires and plugs)
  • On board transmitter (2-way radio)
Both of these codes point toward the Camshaft Position (CMP) sensor circuit. I'd suggest you tell your friend to take a look in that area and start by confirming the sensor wiring is good. Ford has had a history of CMP sensors that fail where they connect to the mechanical drive for the sensor so it is quite possible the CMP sensor is damaged and needs to be replaced.
-Rod
Old Nov 23, 2014 | 11:41 AM
crazy96863's Avatar
crazy96863
Thanks for the response... It does have new plugs & wires so I don't think those would be arcing.
I will suggest, and assist with changing the camshaft position sensor as a first step. I was also planning on a quick once over on all wired and vacuum connections to try and rule those out.
I assume the camshaft position sensor is mounted on the lower front of the engine, by the camshaft/harmonic damper?
Thanks again!
Old Nov 23, 2014 | 11:46 AM
crazy96863's Avatar
crazy96863
Sorry you said camshaft position sensor not crankshaft... Is this around where the water pump might be mounted?
Old Nov 23, 2014 | 10:29 PM
shorod's Avatar
shorod
It might depend on the 4.0L that is in the truck. For the EFI engine (not the SOHC) the CMP sensor is toward the upper rear of the engine. It appears to be pretty much where the distributor would have been mounted if this truck still used a distributor.
On the 4.0L SOHC engine the manual lists the sensor as being located on the LH (driver's side) valve cover.
Maybe someone who has actually replaced the CMP on either of the 4.0 L Explorer engines will chime in with the definitive location....
-Rod
Old Nov 23, 2014 | 10:59 PM
Graygeorge's Avatar
Graygeorge
Had a problem with a 98 4.0 SOHC. located on left valve cover. Took it out, wipe it off and put it back in, ran fine then. Good Luck.
Old Nov 26, 2014 | 11:53 AM
crazy96863's Avatar
crazy96863
Will give that a whirl... Was looking for it in the center of the engine (above the camshaft); assumed it was in the back hidden.
Old Nov 26, 2014 | 12:13 PM
crazy96863's Avatar
crazy96863
Nevermind... Its an OHV... Its hiding in the back.
Old Nov 29, 2014 | 01:55 AM
crazy96863's Avatar
crazy96863
Just wanted to thank you all for the assistance... Changed the camshaft position sensor & the problem seems to be resolved.
On a side note... All the parts stores & the factory stickers indicate this 4.0L to be a SOHC. The engine however is clearly a OHV. This made for a bit of a challenge when sourcing the part. I am wondering if the engine isnt a transplant of some sort...
Did Ford continue to install the 4.0L OHV through the 2001 model year? Kind of weird that they label it something its not.
Old Nov 30, 2014 | 10:54 PM
shorod's Avatar
shorod
Thanks for following up with what you found, and congratulations on the fix.
I'm not sure what to tell you on the OHV versus SOHC. You could check Wikipedia to see when they stopped offering the OHV V6 in the Explorer.
-Rod
vintagequest
Jan 20, 2016 05:02 AM
76250_4x4
Aug 12, 2010 10:09 PM
sweetdreams12477
General Automotive Discussion
Dec 20, 2007 11:00 AM
bodabdan
May 10, 2004 09:35 PM
