Electronics/Radio Gurus
Old Oct 15, 2015 | 09:58 AM
  #31
1972RedNeck's Avatar
1972RedNeck
Originally Posted by TA455HO
Probably stating the obvious, but it sounds like a thermal issue. Once it warms up something drifts out of spec or a cold solder joint that becomes intermittent. There is one thermistor in the system. You'll see it in the schematic I sent you. But, it's probably not the first suspect. Once the problem happens you can try spraying a coolant on various locations and see if cooling in one location improves things. It might help isolate a component or two.
I don't have a way to test it set up out of my truck. When I have it apart I can get it power but what do I do for a speaker? Does it have to be 8 ohm or will any standard speaker work?
What do you recommend for coolant? Aerosol household electronics duster comes to mind as something that get quite cold...
Old Oct 15, 2015 | 11:12 AM
  #32
TA455HO's Avatar
TA455HO
Lead Gopher
The compressed gas duster should work fine. I use an old can of Freon, but not sure it's the safest thing to be using, either.
An interesting test is to put the radio in the refrigerator or freezer and see if it happens, but you'd have to run wires from a power supply (could be an auto battery, too). If the problem doesn't occur under the cooler conditions then that can confirm the thermal intermittent. Larger areas can be cooled by removing the directional spray tube from the can head. The offending component can be isolated by cooling progressively smaller areas of the circuit with the spray tube and a lighter touch on the spray can's button.
A regulated power supply needs to provide about 15 volts and at least 1 amp for this radio. Modern switching power supplies aren't a good choice because the noise from the switching migrates into the radio and you hear it over the speaker. Makes adjusting things a lot more difficult. I use a couple of old 60's era Hewlett Packard power supplies, a 6285A (0-20V, 0-5 A) and 6286A (0-20V, 0-10 A). The second one puts out a lot of juice and is overkill for most radio work.
I use an 8 ohm speaker when working on these guys. The final output amplifier needs to see the right load or it can fry after a few minutes. You can usually get away with a lighter load for a bit but I wouldn't run it too long and keep a finger on the transistor to make sure it's not getting too hot. The big transistor on the front next to the light bulb - you'll have to pull the faceplate to monitor it.
Old Jul 29, 2017 | 01:04 AM
  #33
Rgak1964's Avatar
Rgak1964
So, to revisit an old thread.
Is anyone making/selling the aux cord hack? Or even a usb?
Id like to keep mine as stock as possible, even the radio, but would like more than just AM.
And i don't want to spend 400-600 dollars.
Id even think of shipping mine to get all this done
Old Jul 29, 2017 | 10:07 AM
  #34
daveengelson's Avatar
daveengelson
Came across couple 'how to ' articles may find helpful.
https://www.ford-trucks.com/forums/1...-addition.html
Adding an AUX input to a Stock AM Radio
Ptjsk
Jul 13, 2019 11:09 PM
dotman5614
Jun 24, 2018 03:34 AM
My1964ford
Oct 6, 2015 09:23 PM
stacey77
Sep 9, 2011 02:09 PM
HD74
Mar 19, 2009 11:16 AM
