Sponsored by: Real Truck
block heater
Old Nov 20, 2014 | 10:36 AM
frhrwa's Avatar
frhrwa
block heater
I have a 2002 F250SD 4WD Crew with a block heater (I guess from the factory since I bought it with it installed).. how do I check to see if its working, plugged in doesn't seem to heat anything.. start it in the morning and its still cold? its a 7.3L diesel by the way..
Old Nov 20, 2014 | 10:41 AM
CampSpringsJohn's Avatar
CampSpringsJohn
You can use an ohm meter and check the plug for resistance. On all 3 of my 7.3's the plugs went bad over time. You can either replace the cord, or buy a plug and replace the plug yourself. The end of it gets worn over time that you can see some green showing through at the plug where the wire goes into the plug.
How long do leave it plugged in?
Old Nov 20, 2014 | 11:08 AM
frhrwa's Avatar
frhrwa
I usually plug it in at night, then unplug the next day when I'm ready to go.. I'll check the cord to see if there is any resistance on the line to the block.. thanks..
Old Nov 20, 2014 | 11:37 AM
droldsmorland's Avatar
droldsmorland
You will also hear it when you plug it in. It will start to crackle like a coffee pot or water boiling. Coolant system service is even more of a "must" when using a block heater. Contamination (acidic) will take out a block heater in short order. Coolant sys should be flushed and refilled w/o using tap H20. Then PH checked every 6mo.
GreatWhite99
Jan 5, 2010 09:28 PM
kirkharrod
Dec 27, 2008 09:45 AM
SkySkiJason
Oct 9, 2008 12:47 PM
shendren
Jan 13, 2004 08:48 PM
CHACH
Nov 8, 2003 10:11 AM
