302 vs 347?
Old Nov 20, 2014 | 03:03 AM
Zack88's Avatar
Zack88
302 vs 347?
I'm really leaning towards dropping a small block into my 75 F250 that's getting converted to a regular cab swb, I've never owned a sbf in my life always FE or 385 series.
The truck is mostly just going to be a toy maybe drag around 1500lbs but rarely if ever.
I'm going to stick with a 4 speed, it was a 390 4 speed truck but the engine that came with it is beyond buildable to me.
I like rpms, I want to be able to spin it higher than 5500 and still have it making power. Bottom end torque isn't a huge deal with the standard but I need enough to get the somewhat heavy truck rolling.
I have found a couple of 5.0 HO roller motors I can get reasonable enough to start with but my biggest question is the 347 kit worth the money? Either way it will be getting a new rotating assembly but stock stroke is considerably cheaper.
If I go 347 it will have stock heads with just a valve job and springs put in compared to the money saved sticking to stock stroke would allow me to go with aluminum heads.
What do you recommend for the biggest power gains stroker or aluminum heads?
Old Nov 20, 2014 | 11:38 AM
Conanski's Avatar
Conanski
Why.. this makes no sense. To move a heavy truck with authority you need torque and a 5.0 is pretty weak in that department so you will want more displacement.
The short answer is yes when you're building a truck motor.
If you're spending the money there is no point replacing the rotating assembly with stock.
Stock heads on a 5.0 make peak power at 5000rpm or less, on a 347 they will peak at 4000rpm, so to make a screamer you need better heads regardless. But building a reliable screamer is another thing, the 2-bolt mains on the stock 5.0 block are a known weak point and you will need to swap the stock hydraulic lifters for solids, and if you bump it up to 347 cubes you will need much better heads... like AFR 185s so this is not going to be a cheap build. IMO you would be much better off starting with a 351 and bolting aftermarket heads on it, leave the bottom end stock with upgraded pistons and forget about this screamer nonsense, build it to make peak power at 5500rpm or less.
Old Nov 20, 2014 | 02:48 PM
Zack88's Avatar
Zack88
I plan on putting a main girdle for a little extra insurance, when I say stock rotating assembly I meant stock stroke not factory parts.
The heads sound like a definite necessity either way, I've always had big slow revving motors and 5500 was pushing the upper limit on them with the standard backing it I am looking for a wider power range for each gear and would really like it to get there quick.
I can put 4.56 gears in the truck to get it moving I'm not concerned with highway manners so much.
Old Nov 22, 2014 | 10:25 AM
jimbbski's Avatar
jimbbski
A 351 with a properly set up bottom end will turn 6000 rpm safely. Do that and get better heads and you will be better off then a 347 based 302. The block won't crack and you can even stroke the 351!
A high revving 302 in a light Mustang is fun, but in a truck?
Old Nov 23, 2014 | 01:04 AM
Zack88's Avatar
Zack88
I'm pretty set on going the 351 route after some more research, I am thinking a decent built 351 will give me enough thrill to be happy and possibly in the future a stroker build for it.
Old Nov 24, 2014 | 02:08 AM
baddad457's Avatar
baddad457
Once you add up all the costs of converting that truck to accept a small block, you could have built a biatching 390. Talk about a HUGE step backwards here.
Old Nov 24, 2014 | 02:13 AM
Zack88's Avatar
Zack88
I already have the bellhousing, it's not a big deal to build a set of towers for the stands and I don't have any exhaust or accessories or the mounting brackets for a 390. The block I have is junk and the crank is also. Where is the cost going to add up compared to trying to build and FE from what I have?
Old Nov 24, 2014 | 02:40 PM
baddad457's Avatar
baddad457
Ok, I was under the assumption your truck was complete. I've seen one guy spend a few grand converting an FE pickup to a small block. At a minimum, I'd build on a 94-97 roller 351W, not a 302 based engine.
Old Nov 24, 2014 | 08:19 PM
richter roxs's Avatar
richter roxs
get a 351 roller and stroke it to 408 , best truck combo per $ there is in ford motors
t-bone31
Dec 8, 2014 11:11 PM
dave351m
Sep 4, 2006 08:36 PM
jesse1385
Jun 20, 2005 09:54 AM
DDESELLES
15
May 6, 2005 06:48 AM
1low50
May 29, 2004 11:59 PM
