Which Heads For 302?
Old Jun 17, 2005 | 01:29 PM
jesse1385's Avatar
jesse1385
Question Which Heads For 302?
Hey everyone I will be rebuilding my 302 H.O next week, and I have some questions regarding the heads I should use. First this is a 92' 5.0L H.O out of a mustang, it will be converted to carb with edelbrock performer intake and 600cfm carb. Which stock heads will give me more power the 5.0L heads or heads of a 86' 351W H.O(carburated)?
Old Jun 18, 2005 | 03:38 PM
Kemicalburns's Avatar
Kemicalburns
what is this going into? if its a truck i would not use the stang motor
Old Jun 19, 2005 | 08:01 PM
jesse1385's Avatar
jesse1385
OK first no questions asked the 5.0 is going in the truck, I dont care if you think its underpowered, it will move well enough when I am done with it. If I wanted 400 HP i'd go with a 460. I just asked which head it the best?
Old Jun 19, 2005 | 09:35 PM
cjjeeper85's Avatar
cjjeeper85
I dont think the mustang motor is a bad idea. in its completly stock form it has more power than the older f 150 302's. I'm not sure but i don't think one set of heads has a real advantage over the other. Are you dead set on either the stock heads or the 351 heads? Have you looked into getting the stock heads ported or have you looked into a set of used aftermarket heads?
Just my .02
Old Jun 19, 2005 | 09:39 PM
jesse1385's Avatar
jesse1385
I planed on porting the 302 heads, but if the 351 heads will perform better I will use them.
Old Jun 19, 2005 | 09:43 PM
cjjeeper85's Avatar
cjjeeper85
what are the casting numbers for the 351 heads?
Old Jun 20, 2005 | 09:54 AM
jesse1385's Avatar
jesse1385
I dont know there at someone else house right know. Just know they are stock off of a 86' F-150 with 351W 4V H.O.
