Help with Engine Mount Part#
I really need your help guys with finding the engine mount part number for my X. I've tried to locate the number through ford part online website but was unable to. Here are the truck details:
2000 Ford Excursion 6.8L V10. The truck is 4X2 if that helps.
I need both the left and the right engine mounts.
I'm also trying to find the part # for the complete A/C compressor including the clutch because the one that pops up in the search is an A/C compressor without the clutch assembly.
Thanks guys in advance!
You'll probably need to see a dealer's parts department for the mounts. They seem to be quite scarce (or completely missing) in the aftermarket. Check to see if they're the same or different from the mounts on the 4X4 (which are easily found).
