Compressor for LLS
Old Oct 7, 2006 | 12:25 PM
Jimmygunz3's Avatar
Jimmygunz3
Compressor for LLS
I notice my compressor for the air suspension is getting louder, only before it shuts off. Is there a way to oil it to make it alittle quieter, the rubber mounts are good.....
Old Oct 9, 2006 | 09:58 AM
EagleDakota's Avatar
EagleDakota
It probably gets louder after pumping because of the increased pressure. The mounts may look OK but worn mounts are the usual cause of excess noise. I don't think the compressors themselves are serviceable fir such things as oiling. There is a new bracket and mounting system available. Do a search and you will find the part number. I think I will put a sticky on my monitor since I can never remember the number and this is such a common problem.
Old Oct 10, 2006 | 07:48 AM
Jimmygunz3's Avatar
Jimmygunz3
Thanks alot , I am going to look into replacing the mounts and the bracket
