Front-end experts - does this look right?
At a minimum NEGATIVE TOE on a rear wheel drive vehicle is a HUGE problem and needs to be corrected immediately. A positive 0.1 to 0.25 is more acceptable. On a rear wheel drive vehicle, the natural tendency is for road friction to pull the tires back around the ball joint axis and make even MORE negative toe. This isn't typically a problem around town, but for all the highway driving you do, you NEED POSITIVE toe. Front wheel drive vehicles are the opposite: The power from the engine tries pulling the wheels forward around the ball joint/strut axis and a little negative toe is recommended.
The caster you have isn't enough for our particular road crown around here, but I'm not familiar with the roads in your neck of the woods. 5 degrees on the left and about 4 degrees on the right is where I put SuperDuty trucks. The camber is ok at 0 (and statically, it's perfect) but I'd like to see just a smidgen of positive camber because dynamically when the vehicle is in motion, it changes slightly...then the negative toe that you currently have actually forces the camber negative. I'd go 0.1 to 0.25 degrees on camber just to offset any negative toe that may occur as tie rod ends wear.
The numbers don't look bad up front either but I agree I would want to see more camber. I would also want alittle less caster but that is me. Because I like my FEA specs to be in the middle of spec and within a .25* from side to side. I had a FEA about a month ago and the tech thought I was a ***** with OCD which I am. But the guy did a great job and made me happy. I think it was 2.75* and 2.50* on caster and camber was .50* both sides and 1/16" toe in. I had actually asked for 1/8" toe in Oh well. I'll change the toe myself if needed but I can only judge that when I towing. By the way I couldn't find a shop that had a Hunter FEA machine that would do my dually due to not being able to do a roll out and none of the shops knew how to do a compensation without a roll out.
I know for fact it can be done but whatever. So I had my done on a old school machine with bubble gauges. And for you guys that don't know and tow heavy you would want to make sure that you get .25* to .50* of camber because when you put weight in the back it changes your camber and toe some and even more going down the road. Cody did a great job explaining it.
Just digging for answers with this but has Stinky ever been in an accident?
Now mind you my truck is a 2wd so I don't have seal hub bearing. But I am having a growling issue up front with my wifes Blazer and it's either tires or hub bearings. In the past I have had sealed hub bearing sometimes last 100k and I have had sealed hub bearing go bad in 30k. So just because they have been replaced doesn't mean they are good. The last one that went bad after about 30k I couldn't tell for sure until I had the axle out out of it and then I spun the hub can could hear it. But I got lucky that time because I would have been really mad if I took it all apart and it wasn't bad. Actually at that point I was changing it either way.
Stinky wasn't kissed on the bumper. A drunk driver lost control, flew up an embankment, and came up from under and behind Stinky, smacking him square on the stinger. It lifted him up and moved his *** into the next parking stall. Yes, Stinky was parked. When Stinky did his pirouette, he wedged the car into a tree. My wife and I were facing Stinky from the restaurant and saw the whole thing happen, as did half the patrons in the restaurant. Hit-and-run driver's car bled out 4 blocks from the scene and driver was arrested. There was diamond damage, but it was taken in an squared up at that time.
Side Shift
Front Left
Front Right
Big Bend
We had no problem identifying the driver. Aside from me chasing him while he was driving off (getting a good description and the rear plate number), he left a souvenir.
Oh... and that license frame: It now resides on Stinky's lower lip - like a pirate wearing the earring of one of his victims.
Guys, I really can't stress this enough - there is nothing old in the nose, except the track bar bushings and steering box (looking into that). The front stub axles and bearings - new. Drag link end, ball joints, locking hubs, tires, and whatever I can't remember the name of is new this summer, or within the last two or three years. The front differential was serviced this summer, when the rear differential was rebuilt. All has been inspected by multiple front-end guys that seem to know a little more about the parts up there than I. I swear to gawd... Stinky is a new truck with an old block. These mechanics go for a drive, look at the shiny parts, and go "Whelp - no easy money here. Give him his keys".
Now... if anyone is telling me I have a faulty new part in the nose - please tell me the test to see if the new part is bad.
To each their own. For the amount of highway driving a person has to do around here to get anywhere, more caster is the way to go. If a vehicle were to spend its life in town, I agree, less caster will take a bit of "weight" out of the steering effort needed by the driver. These trucks are heavy in the front and they need more caster to help hold the wheels straight at high speeds.
Rich I am sorry that my input isn't helpful or that spit balling ideas that might pertain to Stinky just aren't any help. But I figured it can't hurt to throw ideas out there and see if any stick?? I believe there is something there but I think the problem is you are too astute which leads to you finding any little nuance in Stinky. I hope you find that needle in a hay stack.
Start the truck, have the friend see-saw the steering wheel back and forth (fairly aggressively). In the meantime, you are under the front end watching for lateral axle movement vs. the frame and/or leaf springs. Also, watch each track-bar end carefully for bushing movement.
The tire-to-ground friction puts a good load on the track bar and axle, vs. the frame, and will show any play in this bar. Of course, there will be a little 'give' in the system due to spring bushings and leaf spring movement, but I suspect you will see that the track bar is tight and is doing its job.
It's difficult for an alignment shop (or you and I, for that matter) to put enough static load on a track bar to see if it's sloppy. You need a dynamic load that will show the slop, if any - and this test is it.
I foolishly bought Energy Suspension track bar replacement bushings before carefully studying by bushings, and it turns out, my OEM bushings are still fine. I felt the truck doing a little side-shuffle when changing lanes and brilliantly thought I had diagnosed the problem. My leaf-sprung Land Cruisers do this too, so part of this chassis nervousness is (I believe) inherent to leaf sprung vehicles, or at least, primitive ones.
Nutshelling it: My last set of tires lasted 18 months - that's $60 a month for tires alone. Everybody that drives the truck agrees something is amiss, beyond normal old-truck syndrome. Almost nobody wants a piece of it (including people unaware of my perfectionist streak). All my efforts and investment can't seem to resolve this one thing that everybody agrees "ain't right". Throw engine shake on there and my spring is wound pretty tight. Being close to home, big flippin' deal - I have a backup vehicle. This will not be the case soon. Going on a long haul through the Cascades and the Sierras in the winter with a Prius has zero appeal - and driving long with mystery engine issues and a shaking fist has less. I wonder if it's too late to buy airline tickets and reserve a rental 4X4.
More Information for TIMKEN 515020
I replaced mine back this spring. I had a growl for a long time. The way I found out these were bad was I jacked up the front and pulled the ABS to squirt some grease in there. It was at this point that I noticed the roughness in turning the hub. To get to the ABS, you have to remove the brake caliper and rotor. With the wheel, rotor, and brake caliper on, I could not notice a problem.
John might be on to something here. Ive been following this thread and as far as FEA goes I'm out !
Now i have gone through 3 sets of front wheel hubs in 155kmi. Orignals lasted 120 or so and i was replacing them with brand X from Advance Auto. Some no name brand. Finally did some research and got the Timkins like John posted in his link. Have Greased them once since 2012. SO FAR...... these Timkins have out done all the others.
Now to relate that to your vibration........ (sorry got off topic a bit, good thing i cant talk into the computer and it type for me ) when ever i had a hub start to go bad or fail man it was almost identical to what you are describing. I could never feel much movement when grabbing the tire but when spun i could hear clicking and popping. Installed new hubs and the vibration shaking was gone.
On your bushings (sway bar , link ends etc ) i have replaced the trac bar back in 2008 i think and link ends at the same time. I know they are bad now because when turning and hitting a hole bump etc i could and now again can hear a popping in my suspension. This went away after i did sway bar link bushings and trac bar bushings. If you are hearing a similar noise in the same scenario then yours might be shot too, but no vibration or shaking from mine.
Don't know if this helps but just thought id do my best to help out
I have a strong suspicion that this could be a case of the wrong alignment specs coupled with a new style of tire that doesn't forgive that, but we'll see.
