Engine mounts
Old Nov 17, 2014 | 11:32 AM
candoo's Avatar
candoo
Engine mounts
Got looking under the F350 with a 352 eyeballing my change to a 390 and was suprised at the engine mounts. The question I have is when I find a 390 is there anything I need to be concerned about. The 352 has a center mount up front and two at the rear. Forgive me as I am a Cleveland man...
Old Nov 17, 2014 | 08:07 PM
smokenchoken's Avatar
smokenchoken
what year truck are we talking about a little more information if you candoo it lol
Old Nov 17, 2014 | 09:09 PM
62fordF250's Avatar
62fordF250
FE 352-360-390 didn't come with the front motor mount integrated into the timing cover. The FT series did though. It is also possible that somebody took the timing cover off of an FT to use on the FE for the front mount. As Smokenchoken says, more info about the truck is needed.
Old Nov 18, 2014 | 07:49 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I'm willing to bet it's a Uhaul F350 cab-chassis, and the engine has the 352 cast in the front
It's a 330MD or whatever the hybrid was that Uhaul dreamed up.
Someone once sent me all the paperwork on his Uhaul 330, gotta get that scanned and posted...
Old Nov 18, 2014 | 08:02 AM
candoo's Avatar
candoo
1966 F350 vin sys 352. 4 spd. reg cab. 2wd.
http://img.photobucket.com/albums/v4...psd75cf97e.jpg
http://img.photobucket.com/albums/v4...ps1c93bd2c.jpg
Old Nov 18, 2014 | 08:10 AM
krewat's Avatar
krewat
So there are two mounts at the bellhousing, and one on the timing cover?
Old Nov 18, 2014 | 08:13 AM
candoo's Avatar
candoo
Yes that correct. I am looking for a 390 right now. Will I have install issues with this unit.
Old Nov 18, 2014 | 08:43 AM
krewat's Avatar
krewat
The current engine is definitely an FE or a 330MD.
A 390 should just bolt in and use the same bellhousing - BUT - keep an eye on the diameter of the crank snout and the dampener and the timing cover seal.
I (and many here) always thought the FT engines were the only ones using the bellhousing and timing cover mounts, but it appears that your particular F350 does too.
Found this, which interestingly enough shows 66-72 F100, and 67-72 F250 4x4 and F350. But NOT your 1966 F350.
Maybe it's time to ask NumberDummy about the motor mount configurations. Maybe the 1966 F350 was considered "medium-duty".
very interesting thread
Old Nov 18, 2014 | 08:50 AM
candoo's Avatar
candoo
VIN # F35YC847371
My current thinking is a 390 install. As I am new to FE's and old trucks getting the right engine to fit is my current concern. Hopefully the NP 435 will take around 300 HP.
If I get a 390 will I require engine mounts and if so will they fit on the frame.
Old Nov 18, 2014 | 09:54 AM
krewat's Avatar
krewat
Like I said, reuse the bellhousing, and the timing cover, and you're good to go - any FE block should fit.
The NP435 will certainly take the power. Certain ones had different 2nd-gear synchros with one better (or worse) than the other, but overall, they are bulletproof unless you run them out of oil.
Old Nov 18, 2014 | 10:05 AM
candoo's Avatar
candoo
Thanks for your help, my 390 search continues....Check out my mustang.
http://vidmg.photobucket.com/albums/...ps49e6c20e.mp4
Old Nov 18, 2014 | 10:32 AM
krewat's Avatar
krewat
Sweet...........
Old Nov 19, 2014 | 08:06 AM
candoo's Avatar
candoo
I got the casting number. C6ME. According to a block casting sheet I have it could be many types. I believe it to be original but a 352 is not listed on my sheet for 1966. The air cleaner shows 352 and the vin code is a 352.
Old Nov 19, 2014 | 09:53 AM
62fordF250's Avatar
62fordF250
Looking at the similar threads I came across this
https://www.ford-trucks.com/forums/722328-352-swap-to-a-390-a.html
So just find or build yourself a 390 and swap out the timing cover from the current engine and maybe the oil pan and pickup tube if the pans are different. Apparently there is such a beast as an FE with a front mount timing cover!
Old Nov 19, 2014 | 11:54 AM
krewat's Avatar
krewat
Adding to the evidence that the 66 F350 is indeed a front-mount engine:
You can see it doesn't have any "normal" motor mounts on the sides.
At least it's a '66-up block. According to this, it is definitely possible:
Ford FE Engine Block Casting Numbers - FORDification.com
But again, Ford casting numbers are a general guide, not definitive. Most of these lists have been cobbled together over the years based on what has been found in vehicles, not what Ford actually in fact did. And even then, sometimes stuff "just happened".
