Niks DIY E fuel, bellows, s366 and trans rebuild
Old 02-17-2015, 01:28 PM
cowmilker08's Avatar
cowmilker08
cowmilker08 is offline
No, I'd do black/silver plus either the blue or red.
  #32
Old 02-17-2015, 01:54 PM
ProjectDually's Avatar
ProjectDually
ProjectDually is offline
Hmm Black/silver would be pretty sweet looking! Especially when you popped the hood. I think I'll settle on straight black, keep it simple. Just gotta figure out how many straights, 45*, and if I'll need any 180* fittings to order. I figure about 20' of AN6 braided should do the trick, plenty left over for spare lines etc.
  #33
Old 02-17-2015, 04:01 PM
nossliw's Avatar
nossliw
nossliw is offline
Well I made the final order today. Fittings and hoses will be here shortly. Turbo and all is installed. Down pipe doesn't even come close to fitting, had a 3" in there previously.
  #34
Old 02-18-2015, 10:13 AM
ProjectDually
Why? Do you need to modify the 3" DP or the firewall to get it to fit now?
  #35
Old 02-18-2015, 10:41 AM
nossliw's Avatar
nossliw
nossliw is offline
I will take a better picture for you where the bellows are placed on this set of up pipes, is right where the down pipe is supposed to go. Not complaining, but yes, I will like have to figure out another 1.5 inches of clearance to get the 3" in there, with the stock pipes I could easily fit a 4" after modifying the firewall as I will need to.
Not the gretest pic, but you can see the bellows hanging out right behind the head where the DP used to go. I can take a snap a picture of the top view if and PM it to you. It shows it much better.
  #36
Old 02-18-2015, 12:28 PM
ProjectDually
Wow, that's some nice work you got going on in there! I see what you are saying though. Is the right bellow as far left as it can go? I've seen some with a bend in them around there to accommodate the DP.
  #37
Old 02-18-2015, 12:34 PM
nossliw's Avatar
nossliw
nossliw is offline
The bellow is positioned where it is going to be (Passenger side?). This is all bolted up and positioned where its final resting place is. I have seen them with the bend as well. If the bellow were lower on that side (plenty of room to put it lower) Than the dp would be a breeze. Oh well.
  #38
Old 02-18-2015, 12:51 PM
ProjectDually
What would be easier? Modifying the firewall, or pulling the up's and cutting them and welding a new bend in?
  #39
Old 02-18-2015, 12:52 PM
nossliw's Avatar
nossliw
nossliw is offline
Firewall if you have a porta power... I do not but might have one shortly :-) I didn't pay for a set that I want to cut apart, I paid for them because I do not have the time to fab my own, not a lack of ability.
  #40
Old 02-18-2015, 02:37 PM
ProjectDually
I hear you, it's convenience over cost.
T-wood
02-27-2018 07:28 AM
NavyLDO
04-17-2013 03:15 PM
92bruiser
11-04-2011 07:54 PM
flainn
06-22-2011 01:01 PM
Dodge/Cummins
15
10-15-2010 11:22 AM
Quick Reply: Niks DIY E fuel, bellows, s366 and trans rebuild
