Headlight Removal a joke
I can't get that bottom squeeze tab to push through.
Blank it T Blank Blank!
Bulb socket is fried. I just pulled/stretched the harness to cut strip for replacement.
Upper clips are no fun either. Maybe rubber is old and stiff after 14 yrs.
Thanks fur listening. LOL
All right I replaced the socket and through in some new Xtravision bulbs.
Very nice improvement from old tired Korean made bulbs I took out.
Socket was definetly loosing current to that side burnt up.
Anybody know the trick to getting that bottom squeeze holder through the hole??
I use a deep 14mm 12pt socket around the lower retainer to depress the tabs while applying some pressure to the back of the headlight, it pops right out.
Yes I did pull clips.
Tako thats a great idea for the bottom! Should of posted this first. Wire stripping wood have ben alot easier.
Hope to check salvage yard for some 02-03 lens soon
