Intermittent Rough Idle
Old Nov 14, 2014 | 04:23 PM
JoeProsen's Avatar
JoeProsen
I have a 2005 6.0 and occasionally it will have a rough idle. Once you accelerate it's fine and has no problem, but the moment you come to a stop light it will start doing it again and then all of a sudden it will idle normally. I already replaced the ICP sensor, but haven't done the pigtail yet. Now today, for the second time ever, it was idling rough for awhile. I made a couple stops and then went through the car wash. By the time I was pulling out of the car wash I could barely accelerate. I unplugged the ICP sensor (thinking that could be the issue), but it still took me about a 1/2 mile to get up to 45mph. Then all of a sudden it runs great again and still is running great. Like I said this is only the 2nd time it's ever gotten that bad, as it's usually just a rough idle. I'd love some input on where to start.
Old Nov 14, 2014 | 05:04 PM
05F250DSL's Avatar
05F250DSL
Kind of sounds like your egr valve is sticking. It is almost center in the front of the intake between the oil filter and alternator. It is held down by two bolts. They can be a bigger to get out so be careful not to break an ear off. While you are cleaning things the iat2 sensor is known to get gunked up as well it is screwed into the I take on the drivers side behind the fuel filter bowl. But without some testing we would be guessing could be low fuel pressure, low voltage Ficm starting to fail. You need a way to see the what the truck is doing to trouble shoot the problem.
Old Nov 14, 2014 | 06:27 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I agree it might be the EGR valve, but I suspect a failing injector.
If it idled as bad as you say, it might have thrown a pending or soft contribution code.
Josh
bc18
Aug 11, 2017 09:28 AM
Heavy Haulin
Apr 30, 2008 10:36 AM
mrl390
Sep 9, 2007 11:42 AM
d_stange
Mar 16, 2006 08:57 AM
Fordtruc526
Jan 18, 2005 11:17 AM
