Rough Idle
Old Jan 12, 2005 | 11:24 AM
Fordtruc526's Avatar
Fordtruc526
Rough Idle
hey, i have an 89 f-150 with a 300 inline...when i first start it up and let it idle for a little bit..it starts to idle rough it jumps from like 1100 to 400 and i really annoys me cause i cant figure out the problem...ive heard rumors that it could be a bad O2 sensor but im not sure
any ideas?
Old Jan 12, 2005 | 12:11 PM
Silver Streak's Avatar
Silver Streak
Have you changed you fuel filter recently? Sounds kinda like the fuel pump is having trouble building enough pressure to start and run during its 2 second prime.
Old Jan 12, 2005 | 01:05 PM
srercrcr's Avatar
srercrcr
you might do a search. Someone else had the exact same problem.
Old Jan 12, 2005 | 05:30 PM
firststep25's Avatar
firststep25
changed O2 sensor and fuel filter and no change in rough idle and missing during low rpm running.
Old Jan 12, 2005 | 08:01 PM
wickymustang's Avatar
wickymustang
Any codes thrown or stored? It could be the IAC needs to be cleaned or replaced as well.
Old Jan 18, 2005 | 11:17 AM
FBerger's Avatar
FBerger
How about your brake booster? Mine idles rough too, and I know I need to replace it. If you pull off the vacuum line to it and plug it, see if it smooths out.
Forest
Jun 3, 2021 11:39 AM
95schauf
Mar 2, 2013 09:39 AM
460
Aerostar
30
Apr 28, 2011 06:19 AM
